rod clearence
Old Jun 14, 2006 | 03:11 PM
GarageAlchemist
Guest
Posts: n/a
Default rod clearence
putting my pitons on my rod is very very very tight.. im actualy marking the piston surfuce a bit trying to get them off. i know they shouldn't be pressed on.. the wrist pins fit just very snuggly... any tips, a little sand paper ?
Old Jun 14, 2006 | 07:10 PM
JDogg's Avatar
Default Re: rod clearence (GarageAlchemist)
what pistons/pins/rods?
Old Jun 14, 2006 | 10:41 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: rod clearence (JDogg)
eagles and weisco,
Old Jun 15, 2006 | 06:24 AM
JDogg's Avatar
i have heard of some problems with that setup not really fitting together... you can take the rods to a machine shop and they can make them fit, or you can take em to the belt sander/grinder and do it yourself
Old Jun 15, 2006 | 07:20 AM
GarageAlchemist
Guest
Posts: n/a
going to do them myself, i was going to use a even surfuce, what grit sandpaper should i use.. also i should do then on the rod side, the piston side, or a little on all.. ?
Old Jun 15, 2006 | 09:01 AM
JDogg's Avatar
use a belt sander or one of the round sanders on the little end of the rod, make sure you use a ball hone or some fine sand paper to clean up the edges so they dont catch the pin.
Old Jun 15, 2006 | 10:39 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
so how were you planning to balance the rods after doing a backyard narrow job on the little end?
Old Jun 16, 2006 | 04:09 AM
JDogg's Avatar
Default Re: (mike_belben@yahoo.com)
it dosnt really matter... its a 180deg motor, balance isnt nearly as crucial as everyone thinks it is.
Old Jun 16, 2006 | 08:55 AM
you know i cant think like that jason, you havent seen the place in a while, im surrounded by everyone elses expensive builds now. hafta be ****.
Old Jun 16, 2006 | 09:06 PM
Tbone's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">it dosnt really matter... its a 180deg motor, balance isnt nearly as crucial as everyone thinks it is.</TD></TR></TABLE>
especially when all the oild from the head drains down the passages and drops on the the counterweights of the crank.. but I too am still **** and balance everything..
mike i need to borrow you rod end balancing fixture if you have one, if not i need you to make me one this week..
Old Jun 16, 2006 | 10:00 PM
JDogg's Avatar
Default Re: (Tbone)
i dunno... i learned to build engines from the best there is, i have study'd and pondered it and cant think of any reason to worry with it.
Old Jun 17, 2006 | 06:28 AM
Tbone's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">i dunno... i learned to build engines from the best there is, i have study'd and pondered it and cant think of any reason to worry with it.</TD></TR></TABLE>
In case you missed it, i agreed with you and gave people an example why balancing on a inline 4 isnt needed as much.. The oil from the topend drains onto the crank so it throws the balance completely out..
Old Jun 17, 2006 | 07:18 AM
JDogg's Avatar
Default Re: (Tbone)
that was more of a reply to mike than you tbone... but yeah... oil balances things good
Old Jun 17, 2006 | 03:26 PM
i figure if one rod weighs more than the others, particularly the pin end as that is purely reciprocating motion, then by 9k, it will have a good deal more effective mass than the others and could be the heavier pulse in the cycle.. i imagine it in my head as being the heavier "beat" for the balancer to dampen.
and i do my best to keep oil off the crank.
tom- i made a balancing swing a while ago, youre welcome to come grab it anytime.
Old Jun 18, 2006 | 06:16 PM
JDogg's Avatar
sush mike
CaliforniaDad
Jun 30, 2011 11:44 PM
Aquafina
10
Jul 16, 2007 12:25 PM
Muckman
Dec 19, 2005 10:27 PM
vtecmonster001
Jan 13, 2005 08:12 AM
paulzy
Aug 24, 2001 03:28 PM
