Question about backpressure...
Old Jun 14, 2006 | 02:59 PM
EFstyle's Avatar
Default Question about backpressure...
i was just woundering if not having a muffler on your car would make u loose power due to the lack of back pressure?
Old Jun 14, 2006 | 03:01 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Question about backpressure... (EKEJ6)
Back pressure is a myth. You want as little back pressure as possible. Back pressure can make you feel like you've found power, but in reality it just shifts peak torque further down the RPM band and kills top end hp and torque.
End of discussion. Search for answers to your basic physics myths, okay?
Old Jun 14, 2006 | 03:16 PM
H22a1civic's Avatar
Default Re: Question about backpressure... (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Back pressure is a myth. You want as little back pressure as possible. Back pressure can make you feel like you've found power, but in reality it just shifts peak torque further down the RPM band and kills top end hp and torque.
End of discussion. Search for answers to your basic physics myths, okay?</TD></TR></TABLE>
This is not entirely true. Honda's thrive on back pressure unless you are going to be launching it at high rpm's. If it was a drag car, then yeah you have no need to worry about it. But if you are asking about this on your daily driver. Then yes you need the back pressure. It will give you more low end trq and a better launch if some one just pulls up to you at a light. There's no need for you to be reving the sh*t out of your car on the streets. Top end isnt going to matter to much, it really isnt going to set you back at that big of a difference.
Old Jun 14, 2006 | 03:21 PM
FalkenSiR's Avatar
Default Re: Question about backpressure... (H22a1civic)
sorry I just had to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22a1civic &raquo;</TD></TR><TR><TD CLASS="quote">It will give you more low end trq and a better launch if some one just pulls up to you at a light.</TD></TR></TABLE>
Old Jun 14, 2006 | 03:28 PM
H22a1civic's Avatar
Default Re: Question about backpressure... (fast95eg8)
Hahaha.....yeah I know, I just meant that metaphorically speaking.
Old Jun 14, 2006 | 03:35 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Back pressure is a myth.</TD></TR></TABLE>
This is more or less correct. Read up:
http://www.miata.net/garage/Kn....html
http://www.uucmotorwerks.com/h...h.htm
http://www.nsxprime.com/FAQ/Mi...y.htm
Old Jun 14, 2006 | 03:42 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22a1civic &raquo;</TD></TR><TR><TD CLASS="quote">It will give you more low end trq and a better launch if some one just pulls up to you at a light. There's no need for you to be reving the sh*t out of your car on the streets. Top end isnt going to matter to much, it really isnt going to set you back at that big of a difference.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Back pressure can make you feel like you've found power, but in reality it just shifts peak torque further down the RPM band and kills top end hp and torque.</TD></TR></TABLE>
Thanks for being misinformed though
Furlanetto
Oct 6, 2014 12:35 PM
Urban_LegendGS-R
12
Apr 22, 2008 03:22 PM
civickid03
Apr 12, 2007 11:27 AM
NoLipRacen
Mar 8, 2004 02:11 PM
onyx00
May 23, 2002 06:57 AM
