Tech Question, Back Pressure?
Old May 23, 2002 | 06:48 AM
onyx00's Avatar
Default Tech Question, Back Pressure?
What's the story behund back pressure. I mean, do you want some back pressure or is having zero back pressure the way to go? i was under the impression you wanted to have some back pressure, but recently I was told you wanted none. Just confused. Thanks
sgT's Avatar
sgT
Default Re: Tech Question, Back Pressure? (onyx00)
you want none
however you dont want too big of an exhaust as you want the pulses to help
each other.
Old May 23, 2002 | 06:54 AM
onyx00's Avatar
Default Re: Tech Question, Back Pressure? (sgT)
By pulses you mean the energy from the exhaust helping to pull exhaust out of the other cylinders? Same principle as a Mustang V8 using an X-pipe right?
So then theoretically (sp?) a test pipe should produce more HP than a cat? how does having zero back pressure affect torque? Will you loose torque with less back pressure?
Old May 23, 2002 | 06:55 AM
sgT's Avatar
sgT
you dont lose anything if the pipes are setup properly.
the "loss" you feel is all mental i assure you
Old May 23, 2002 | 06:57 AM
DutchITR1689's Avatar
You don't need backpressure! The only thing you need is to preserve the wave (pulses) energy from the exhaust gasses. This means don't narrow and don't widen the header tubes.
lambo95
Dec 17, 2006 12:20 PM
EK FLY
16
Oct 6, 2006 12:27 PM
ZoRG
Jan 13, 2004 02:44 AM
jansenrw
Jun 20, 2003 01:25 PM
