gsr block with b16 head??
will a b16 head bolt right onto the gsr block?? i have a 96 gsr block and a 95 b16a head.. just wondering if i can put these two together or will i have to get a gsr head for the gsr block??
yes it does bolt on....basically what you are creating is a poorman's ITR setup.
since ITR/CCTR uses a B16A its no brainer, but by using the the orignal piston the c/r will drop by about .2 to 9.8 which is rather low for dohc vtec motor....time either to go with ITR pistons or if you dare CTR ...all will work well
btw b16a head flows much better then the GSR its a good combination
http://www.c-speedracing.com/howto/c.../compcalc.html
Eh, it's a little better. But the pistons are still subject to detonation.
Cast pistons won't hold as well as a forged.
So, you get a little protection, but not much.
b16a head + usdm gsr block + usdm itr pistons = 10.8 CR
Everything will work out alright. If you want to cheaply drop the compression a little more, just get some Integra LS pistons. They'll give you something around 9.3:1 compression.
b16a head + usdm gsr block + usdm gsr pistons = 10.0 CR
Also, with USDM ITR pistons its 10.6:1 (same as USDM ITR motor)
even better is using the B16a PR3 piston (USDM Si) at 11.0:1
check it here:
http://www.bojangs.com/calculator
[Modified by Trey, 2:31 PM 4/17/2002]
they are 9.8:1 not 10.0:1 (Stock USDM GSR motor is 10.0:1)
check it here:
check it here:
thanks for the info guys.. i'm planning on boosting about 5 psi so hopefully the stock pistons will hold up.
..yesh it will, just make sure you use B18C head studs and not B16A head studs (they're shorter).
