what would happen b18c head on a b16a block
Old Jun 16, 2003 | 09:16 PM
jdmbuilt's Avatar
Default what would happen b18c head on a b16a block
please don't ask why someone would do this.
but what would the ups and downs of this be?
thanks a lot.
Old Jun 16, 2003 | 09:22 PM
porsche997dc2's Avatar
Default Re: what would happen b18c head on a b16a block (jdmbuilt)
there's nothing wrong doing this setup. The head bolt in perfectly. Sometimes, you do what ever is available to you.
Old Jun 17, 2003 | 01:47 AM
pissedoffsol's Avatar
25 Year Member
it will bump your compression about .2 points, and you would need the IM of the gsr as well, due to the different bolt patterns
Old Jun 18, 2003 | 08:07 AM
turbo*s2k's Avatar
Default Re: (pissedoffsol)
I know that you would use the head bolts from the GSR if you were using a GSR block, and a b16 or type r head. So I"m assuming in this case a B16 block with GSR head you would use the B16 head bolts correct?
Old Jun 18, 2003 | 11:49 AM
Kataku2K3's Avatar
Default Re: (TurboChrgd_Civic)
Yup, just use the B16A headbolts, they're meant for the 263mm block... As pissedoffsol said, you will get an increase of ~0.20:1 at std. bore... B16A with 81mm PR3 slugs ~10.4:1, with P30's ~10.6:1... Good Luck
Old Jun 18, 2003 | 12:05 PM
TodaCivic's Avatar
Default Re: (Kataku2K3)
I had that setup for a little while... sold the car like that too..eheh.
It gives alot more low end tq... something b16's need badly.
I removed the secondary butterflies since i had si ecu... it pulled nicely all the way to 8k.
I would say like the other guy said... you do what you can afford soemtimes.
4g4dcruisin
10
Sep 4, 2009 09:22 AM
nolicense526
Oct 15, 2007 10:46 PM
JALOP B16
Dec 31, 2002 02:17 PM
The Mole
Dec 5, 2002 09:29 PM
Euphoria81
Feb 21, 2002 07:41 AM
