Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help please !!!
Old Jun 14, 2006 | 08:49 AM
hadzo's Avatar
Default Help please !!!
I’m puzzled, the car feels very unstable at higher speeds (60 + mph to be exact)… it feels like it wants to go left to right and that makes it kind of difficult to keep it going straight, now I also experience some vibrations but I’m assuming that its form the wheels since they are bent a little.
Real question; could this be an alignment issue??? At lower speed it feels fine but as soon you reach highway speeds it just feels lose, like it wants to get away from ya….
Please any input is appreciated, thanks.
Old Jun 14, 2006 | 09:02 AM
fventura03's Avatar
bent wheels? you've just answered your own question.
if they weren't bent, i'd suggest to get your wheels balanced, if that didn't work, get an alignment.
Old Jun 14, 2006 | 09:56 AM
hadzo's Avatar
Default Re: (fventura03)
I thought a bent wheel would cause nothing more then vibration but what about the part where the steering feels so light and it is so hard to keep the car going staraight ... very har to keep the car in control .... feels like I am losing control of the car ????
If all of that is bent wheel then I guess, thats what I will do, replace the wheels and get an alignment done ...
If it comes back I'll be here again LOL
Old Jun 14, 2006 | 11:33 AM
toyomatt84's Avatar
Sanji
You'll need a replacement or repair for the bent rim, and an alignment to fix this problem. *Don't forget to have the wheel balanced.
Old Jun 14, 2006 | 11:13 PM
brjhnson's Avatar
Default Re: (toyomatt84)
also check you power sterring flued
Old Jun 16, 2006 | 12:22 AM
LowTec MOHawk's Avatar
Default Re: Help please !!! (hadzo)
its possible that your bent wheel/wheels are causing a wandering issue but i highly doubt it......its more likely that when your wheel/wheels got bent the caster got pushed out of spec. by a bent control arm or a shifted subframe or a bent strut ect.
if your caster is out 0.5 degrees or more from side to side then the vehicle tends to wander around.... if i remember correctly thats from having too little caster or a more negative reading. id get it into an alighnment shop
Old Jun 16, 2006 | 06:12 AM
hadzo's Avatar
Default Re: Help please !!! (mikeformos03dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeformos03dx &raquo;</TD></TR><TR><TD CLASS="quote">its possible that your bent wheel/wheels are causing a wandering issue but i highly doubt it......its more likely that when your wheel/wheels got bent the caster got pushed out of spec. by a bent control arm or a shifted subframe or a bent strut ect.
if your caster is out 0.5 degrees or more from side to side then the vehicle tends to wander around.... if i remember correctly thats from having too little caster or a more negative reading. id get it into an alighnment shop</TD></TR></TABLE>
That makes sence, I guess I'll have to do that, just waiting for some cash, lol, thanks guys, thank a million
Old Jun 16, 2006 | 04:13 PM
pon55's Avatar
toe-out!
This makes the car "hunt" (go all over the road). thats why we have "toe-in"
Old Jun 21, 2006 | 07:09 AM
zhuman06's Avatar
Yeah I had that exact problem with my first set of wheels. I tried getting it balanced and an aligned and it still didn't work. The way I had to do it was get a whole new set of wheels which was expensive.
msinsky14
49
Jan 27, 2011 08:10 AM
slowej1
Suspension & Brakes
Jul 23, 2009 08:35 AM
G2_Fella
May 8, 2009 08:38 AM
SlowSOHC-T
Oct 31, 2005 01:11 PM
jdmstreethatch
Jan 11, 2004 04:28 PM
