Honda S2000 Honda S2000
Help: Hazard lights not working
Old Jun 14, 2006 | 08:44 AM
TomTomTuning's Avatar
Default Help: Hazard lights not working
Hey every one.
Background:
Just picked up my S2K (woohoo)
Got it in MO (i live in PA)
Problem:
So when I pulled over on the side of the road, to switch drives (13hour drive back home)
I put the hazards on. It was on for like 15sec, and then I notice it wasn’t on any more.
When I hit the button, i hear a click in the dash (single click) and they don’t turn on
Could it be a Fuse, but why would i hear the click in the dash?
Could it be a relay of some sort?s
Modified by Yoshi S2K at 10:10 AM 6/14/2006
Old Jun 14, 2006 | 09:57 AM
SilverDc2's Avatar
Default Re: Help: Hazard lights not working (Yoshi S2K)
sounds like a fuse, do your turn signals still work?
Old Jun 14, 2006 | 11:38 AM
Default Re: Help: Hazard lights not working (SilverDc2)
Yes the trun signals work fine..
thats why i dont know whats going on..
Old Jun 14, 2006 | 12:12 PM
Francesco's Avatar
if it clicked its a good chance its the relay.
now here is the question...
- are the hazards and turn signals on the same relay?
Old Jun 14, 2006 | 12:36 PM
BKHs2000's Avatar
CHECK TO SEE IF YOU HAVE POWER INTO THE SWTICH. THERE ARE THREE WIRES YOU NEED TO CHECK. THE WHT/BLK WIRE IS A POWER WIRE FROM FUSE 49 (10A), THE RED/BLU WIRE IS A POWER WIRE FROM FUSE 7 (7.5A), AND THE BLK/RED WIRE IS A POWER WIRE COMING FROM THE TURN SIGNAL/HAZARD RELAY. LET ME KNOW WHAT YOU FIND.
Old Jun 14, 2006 | 12:54 PM
Default Re: Help: Hazard lights not working (BKHs2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Francesco &raquo;</TD></TR><TR><TD CLASS="quote">if it clicked its a good chance its the relay.
- are the hazards and turn signals on the same relay?</TD></TR></TABLE>
I have a Service manual (on disk) that i will take a look at
Maybe there are some Wiring schematics on it that will show me if the Hazards are on
the same Rely as the Turn signals
ill also check fuses, make sure none are blown
it really upsets me that i just got the car, it worked for 5sec's and then GONE !!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BKHs2000 &raquo;</TD></TR><TR><TD CLASS="quote">CHECK TO SEE IF YOU HAVE POWER INTO THE SWTICH. THERE ARE THREE WIRES YOU NEED TO CHECK. THE WHT/BLK WIRE IS A POWER WIRE FROM FUSE 49 (10A), THE RED/BLU WIRE IS A POWER WIRE FROM FUSE 7 (7.5A), AND THE BLK/RED WIRE IS A POWER WIRE COMING FROM THE TURN SIGNAL/HAZARD RELAY. LET ME KNOW WHAT YOU FIND.</TD></TR></TABLE>
Would i hear the single click noise in the dash.. if it didnt have power?
Ill use my multimetter and check and see if there is power to the Switch.
and if there is power at the switch, maybe the switch Died ?
i hate to take it to honda to get checked out, but i might just do so.
Old Jun 14, 2006 | 02:38 PM
BKHs2000's Avatar
I am a Honda tech in Colorado, I was looking at an etm the turn signals and the hazards both go through that switch. More than likely if you have turn signals and no hazards youre problem will be fuse 49 or 7. Fuse 49 is located in the main under-hood fuse/relay box and fuse 7 is located in the under-dash fuse/relay box.
hope it helps.
Old Jun 14, 2006 | 10:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BKHs2000 &raquo;</TD></TR><TR><TD CLASS="quote">I am a Honda tech in Colorado, I was looking at an etm the turn signals and the hazards both go through that switch. More than likely if you have turn signals and no hazards youre problem will be fuse 49 or 7. Fuse 49 is located in the main under-hood fuse/relay box and fuse 7 is located in the under-dash fuse/relay box.
hope it helps.</TD></TR></TABLE>I will go a head and check that out ASAP, i really appreciate the help
Old Jun 15, 2006 | 10:58 AM
LBBP R's Avatar
check the bulb.
Old Jun 15, 2006 | 01:00 PM
mykcuz's Avatar
Default Re: Help: Hazard lights not working (LBBP R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBBP R &raquo;</TD></TR><TR><TD CLASS="quote">check the bulb.</TD></TR></TABLE> the bulb? he said all 4 hazards arent working...it sucks that something stupid like that hppened, but dont let it overrun all that is right with ur new purchase...i doubt the seller rigged the fuse to work for short term, its just one of things that happens when cars have thousands of functioning parts.
Old Jun 15, 2006 | 01:14 PM
Default Re: Help: Hazard lights not working (mykcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mykcuz &raquo;</TD></TR><TR><TD CLASS="quote"> the bulb? he said all 4 hazards arent working...it sucks that something stupid like that hppened, but dont let it overrun all that is right with ur new purchase...i doubt the seller rigged the fuse to work for short term, its just one of things that happens when cars have thousands of functioning parts.</TD></TR></TABLE>
Yea all of the bulbs work, because the turn signals work fine.
I am currently at work, but when i get off, i will be taking a look at the hazard light Fuse. i hope this is the problem
But believe me its not that big of a deal but slightly frustrating
Old Jun 15, 2006 | 01:22 PM
Mr. Projekt's Avatar
* B A N N E D *
It's a fuse. Underdash. Fixed it for a friend recently.
Old Jun 15, 2006 | 01:44 PM
Default Re: Help: Hazard lights not working (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">It's a fuse. Underdash. Fixed it for a friend recently.</TD></TR></TABLE>
Was it the same issue i was having ?
Ill figure out if its my fuse, as soon as i get to my garage..
ill make sure to let every one know if it was the fuse..
Old Jun 15, 2006 | 02:16 PM
S2KJ55's Avatar
check the fuse that happend to some guys s2000 that i know and it was the fuse......but good luck!
TooManyHobbies
Sep 22, 2014 05:12 PM
I Love My 4 door
Dec 19, 2010 04:05 PM
efjones9
Audio / Security / Video
Jun 10, 2009 08:33 AM
SIMATIC
Jul 30, 2003 01:19 PM
ScottEK
Jul 24, 2003 08:59 PM
