Flash lights with keyless?
Old Jul 24, 2003 | 01:00 PM
ScottEK's Avatar
Default Flash lights with keyless?
I installed a keyless entry system on my car a couple days ago. I left an extra wire tapped into the lock wire to trigger a relay later. I have (2) 12v 30a relays but I'm guessing I'll just need to use one. My question is where do I tap into a wire to get the parking lights to flash when I press lock? And if anyone can give me a quick rundown on what each spot on the relay does that would help to. It's in a 90 CRX if you need to know that. Thanks
Old Jul 24, 2003 | 02:04 PM
romeo619romeo's Avatar
Default Re: Flash lights with keyless? (beta13)
accesory in the fuse box... there shoudl be one where it works along with it.. just have to turn your headlight on and use a testlight
Old Jul 24, 2003 | 08:02 PM
ScottEK's Avatar
Default Re: Flash lights with keyless? (romeo619romeo)
Give voltage to one of the fuses? That does not sound right?
Old Jul 24, 2003 | 08:59 PM
o_Rage_o's Avatar
the fuses simply act as an intermediary between the battery and your load - if the load pulls more power than it needs it cuts out.
If you cut (edit) the wire before, or after the fuse to insert your power to turn on and off the accessory momentarily the fuses will still be getting power.
If you make a mistake - fuse blows :D
-Rage
TooManyHobbies
Sep 22, 2014 05:12 PM
TomTomTuning
Honda S2000
13
Jun 15, 2006 02:16 PM
xsuperdanx
May 11, 2003 04:31 PM
B18EG6
Mar 20, 2002 09:29 PM
nerdish
Aug 9, 2001 03:13 PM
