Wiring Confusion
Old Jun 13, 2006 | 03:37 PM
Silver Slug's Avatar
Default Wiring Confusion
I am installing a 96 Spec JDM B18C into my 2000 Civic HB. i was wondering if anyone would have any information on the wiring harness i require and if the ecu that came wit the motor P72 OBD2A would work wit it. Thanks
Old Jun 13, 2006 | 04:47 PM
j spec's Avatar
Default Re: Wiring Confusion (Silver Slug)
in my opinion your easiest option would be to use a 92-95 civic ex, si or 94-95 integra gsr harness the way i understand yours is probably cut or is for the wrong side of the engine bay. as for the ecu i am not sure if your car being obd2b and the ecu being obd2a will be a problem. however i do know it can be used with minor modifications that is if any are needed at all. Also 96-01 integra gsr harness can also be used with some minor modifications
xft
12
Oct 17, 2008 05:06 AM
97_hatch
Jun 11, 2008 10:28 PM
MRturbo
Jun 24, 2006 06:36 AM
jadsi420
Aug 14, 2005 07:27 AM
length
Dec 2, 2003 08:21 AM
