Wiper Switch will not turn OFF!
Old Jun 13, 2006 | 08:45 AM
zebra_fish's Avatar
Default Wiper Switch will not turn OFF!
The wiper switch will not turn off on my 93 civic LX sedan 1.5. Whats involved in swaping out the switch? Do I need any special tools? thanks
Old Jun 13, 2006 | 11:06 AM
JDM knowledge's Avatar
Default Re: Wiper Switch will not turn OFF! (zebra_fish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zebra_fish &raquo;</TD></TR><TR><TD CLASS="quote">The wiper switch will not turn off on my 93 civic LX sedan 1.5. Whats involved in swaping out the switch? Do I need any special tools? thanks</TD></TR></TABLE>which switch? the one on the steering column or the actual motor?
if you mean the one on the column, you have to take off your steering wheel. Torque bit, 19mm socket, phillips screw driver...
Old Jun 13, 2006 | 11:27 AM
zebra_fish's Avatar
Default Re: Wiper Switch will not turn OFF! (JDM knowledge)
Its the one in the stering column, I think a spring broke. The switch hangs down and stays on. It goes off if you hold it up.
Old Jun 13, 2006 | 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zebra_fish &raquo;</TD></TR><TR><TD CLASS="quote">Its the one in the stering column, I think a spring broke. The switch hangs down and stays on. It goes off if you hold it up. </TD></TR></TABLE>
yeah that springs is kind of flimsy. Make sure to unplug your battery before you remove your steering wheel. You have to remove all the SRS componenets and stuff also. You wil see it once you remove the steering wheel. Should take no longer than an hour.
Old Jun 13, 2006 | 01:38 PM
Relic1's Avatar
if the handle hangs down and switches itself on, the switch snapped internally. time to replace it.
just in case, here is how to remove it from the car and clean it up.
http://www.b18c5eg.com/how2/wiperswitch/
AJZerick
Mar 18, 2008 06:24 PM
bmccoy007
Jul 26, 2007 07:56 PM
mrdeadman
Audio / Security / Video
Sep 23, 2006 08:52 AM
SR20 Inside
Jan 25, 2006 09:24 PM
crewjones
Oct 27, 2003 06:51 AM
