Electrical Problem, dizzy goin bad?
Old Jun 13, 2006 | 07:56 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Electrical Problem, dizzy goin bad?
On my way to work this morning my engine lost all power.
When I put my foot on the gas, it felt like it was getting alot of fuel, but no spark.
I was havin problems last week w/ what seemed like a missfire so I replaced the plugs, wires, rotor, cap and the car ran fine.
What do you guys think, is my dizzy goin bad?
Old Jun 13, 2006 | 08:38 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Electrical Problem, dizzy goin bad? (EJ8VTEC)
bump
Old Jun 13, 2006 | 08:41 AM
stock_honda_coupe's Avatar
Coils tend to go out. My car sputtered for a while then died for good.
Old Jun 13, 2006 | 08:43 AM
jdeemseerx's Avatar
what do you mean it lost all power? did it die on you, stuttering, misfiring? a lil more info could help alot with the advice you get on here
gabebauman's Avatar
Default Re: Electrical Problem, dizzy goin bad? (stock_honda_coupe)
Did a large space craft land or hover nearby?
Old Jun 13, 2006 | 08:48 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Electrical Problem, dizzy goin bad? (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">Did a large space craft land or hover nearby? </TD></TR></TABLE>
lmao
it kinda sputters and i slowly loose speed.. Then when I give it gas, it bogs like its getting flooded..
It happened twice today.. the 1st time I pulled over for about 30 sec and then it ran fine.. the other time I turned off the key while still on the highway then turned it back on, and it ran fine.
Old Jun 13, 2006 | 09:43 AM
EK79's Avatar
try to replace the dizzy and see what happens
good luck
Old Jun 13, 2006 | 10:02 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Electrical Problem, dizzy goin bad? (stoopid monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stoopid monkey &raquo;</TD></TR><TR><TD CLASS="quote">try to replace the dizzy and see what happens
good luck </TD></TR></TABLE>
if i had or wanted to spend hundreds of $ on it i would.. i dont wana buy **** that I dont need... which is y im asking if it sounds like a dizzy problem... thanks for all your help
NJcoupe's Avatar
Time to bust out the multi-meter and try to diagnose what is going bad with checking each sensor inside the distributor for the correct voltage and amperage.
Old Jun 13, 2006 | 10:04 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Electrical Problem, dizzy goin bad? (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">Time to bust out the multi-meter and try to diagnose what is going bad with checking each sensor inside the distributor for the correct voltage and amperage.</TD></TR></TABLE>
see, the problem is I dont kno much about the inside of the dizzy itself.. i would need a diagram of exactly what i should be checking...
also, the prob doesnt happen all the time, like i said in a prev post, when i turn off the ign then back on, it ran fine..
Old Jun 13, 2006 | 10:32 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">see, the problem is I dont kno much about the inside of the dizzy itself.. i would need a diagram of exactly what i should be checking...
also, the prob doesnt happen all the time, like i said in a prev post, when i turn off the ign then back on, it ran fine.. </TD></TR></TABLE>
Read thru these:
https://honda-tech.com/zerothread?id=1516648
https://honda-tech.com/zerothread?id=1512247
https://honda-tech.com/zerothread?id=1541940
MeGotRoundEye
11
Dec 31, 2007 05:49 AM
...:::MaRk:::...
13
Jul 23, 2007 08:40 PM
totsie7944
Feb 19, 2007 03:53 PM
luderollin
Dec 13, 2006 02:54 PM
V-Grip! Teknic73
Jul 8, 2003 01:05 PM
