gauge question
gauge question
i got a b18c swap put in a del sol si... well im about to chip my ecu to take off the governor and i needa change my tach casue the redline says 7200 instead of 8200 well anyway and my speedo says 125 so leading to my question..
http://www.autometer.com/cat_g...zid=6
i found those guages... question is is 3 3/8's the correct size? will those fit right in?
Re: gauge question (DelSolMarine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine »</TD></TR><TR><TD CLASS="quote">i got a b18c swap put in a del sol si... well im about to chip my ecu to take off the governor and i needa change my tach casue the redline says 7200 instead of 8200 well anyway and my speedo says 125 so leading to my question..
i found those guages... question is is 3 3/8's the correct size? will those fit right in?</TD></TR></TABLE>
They will not fit in directly without modification. Best bet, is to ignore the tach, and get a shiftlight with the light set at 7200.
Re: gauge question (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">They will not fit in directly without modification. Best bet, is to ignore the tach, and get a shiftlight with the light set at 7200. </TD></TR></TABLE>
Heh, shift point in a GSR at 7200, that's kinda funny.
Do what he said, but set it at 8100 (give yourself some time to react)
Delsol_Drew
10-17-2014 04:41 PM
