MAP sensors.... what's the dif from one on firewall and one on TB?
Old Jun 12, 2006 | 05:21 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default MAP sensors.... what's the dif from one on firewall and one on TB?
I have a 91 DA Integra (OBD0 converted to OBD1 for swap), I use the MAP on the firewall which has a vacuum line attached to the IM (the OBD0 MAP that was used when the car was dyno tuned). I have a ITR TB which has a MAP on it as well and would like to clean up my engine bay. I have extended the wires but would like to know what, if anything, will be different about usiing this MAP on the TB.
Thank you all for your help...
Old Jun 12, 2006 | 11:39 PM
BuddhaSiR's Avatar
Default Re: MAP sensors.... what's the dif from one on firewall and one on TB? (DAantagonist)
should be able to use either one. i'm not sure but i believe they work the same.
Old Jun 13, 2006 | 06:06 AM
Default Re: MAP sensors.... what's the dif from one on firewall and one on TB? (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">should be able to use either one. i'm not sure but i believe they work the same.</TD></TR></TABLE>
tried to use the other one....and it idle hunted quite a bit.
Old Jun 13, 2006 | 08:36 AM
BuddhaSiR's Avatar
Checked some schematics. The map sensors are wired differently. To be able to use the ITR TB you need to rewire it.
ITR: Terminal 1 = 5 volt reference
Terminal 2 = Sensor ground
Terminal 3 = Sensor input
91: Terminal 1 = sensor input - yellow/red wire
Terminal 2 = 5 volt reference - white wire
Terminal 3 = Sensor ground - green/white wire
Old Jun 13, 2006 | 12:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">Checked some schematics. The map sensors are wired differently. To be able to use the ITR TB you need to rewire it.
thank you so very much.
likwidchz
Engine Management and Tuning
Aug 9, 2016 05:12 PM
Ef4doorwagon
Feb 12, 2014 09:25 AM
JDM JEFFREY
11
Oct 13, 2009 11:55 AM
eg:R
Jun 11, 2006 12:25 PM
dpine
Jan 17, 2005 01:22 PM
