DA abs to non abs conversion gone bad please help!
Old Jun 12, 2006 | 03:43 AM
teggy2uner18's Avatar
Default DA abs to non abs conversion gone bad please help!
I've searched all of HT and cant find a write up on a 90 integra abs to non abs conversion. This is what happens I will drive the car around for a little bit then I can start to feel the pedal get a lil bit harder everytime I use it and eventually the front brakes lock up and the pedal is so stiff I cant move it. I crank the wheel to the side and crack the bleeder then all is good for awhile then it happens again. I did the conversion from abs to non abs for more room and less weight, this is all that I did.
Brand new 90 integra rs master cylinder
Used honda 40/40 prop. vale
All new brake lines/rubber hoses/fittings
I still have the abs brake booster and calipers and im not sure if these need to be replaced
There is no air in the lines at all I vaccum bleed them in the proper sequence and bench bleed the master cylinder.
Please let me know what you guys think I hate driving my da like this.
Old Jun 12, 2006 | 11:14 AM
NJcoupe's Avatar
Default Re: DA abs to non abs conversion gone bad please help! (teggy2uner18)
Did you remove the hose from the booster to the manifold? If so are you shure its on correctly as it works as a check valve.
Old Jun 13, 2006 | 12:42 PM
I had it off for awhile but the check valve still works properly
megatoninduk
Jun 13, 2010 02:36 PM
ls19integra95
Nov 22, 2007 09:35 PM
Chim Chim
Mar 31, 2007 07:36 AM
highcomp
Apr 15, 2004 07:36 PM
spencedogg
Oct 5, 2003 06:06 PM
