quick spring retainer install question. for all you mad mechanics
Old Jun 11, 2006 | 08:45 PM
j spec's Avatar
Default quick spring retainer install question. for all you mad mechanics
well just getting ready to install my portflow springs/retainers in my gsr hatch and i was wondering if i need to pull the rocker arms and the shafts they ride on out to get to the springs and retainers? oh im doing this with the head on the engine and a valve spring compressor that bolts to the head.
Old Jun 11, 2006 | 09:32 PM
Takumi Fujiwara's Avatar
Default Re: quick spring retainer install question. for all you mad mechanics (roma's GSReg6)
If you're doing it with the head on the car, make sure you pressurize the cylinder so you don't drop a valve.
And you don't need to pull anything except the parts you need to get off to get the cams out.
Tweezer-type tool will help you out here.
Old Jun 11, 2006 | 10:11 PM
j spec's Avatar
Default Re: quick spring retainer install question. for all you mad mechanics (Takumi Fujiwara)
thanks tak and i pressurized the cylinders to 100psi.
Old Jun 11, 2006 | 10:39 PM
should be plenty of pressurization. try not to drop any of the keepers...
90AccordVTEC
Jun 22, 2006 04:51 AM
j spec
Jun 12, 2006 07:52 AM
D50boy
Feb 24, 2006 06:56 AM
JunIntegra
Apr 11, 2003 05:15 PM
KoRE
Mar 13, 2003 06:42 PM
