little black marks on cylinder walls?
Old Jun 11, 2006 | 07:58 PM
the.hamburglar's Avatar
Default little black marks on cylinder walls?
i just ripped apart my block and i see some little black marks on the cylinder walls and a few on the crank journals. i know these are heat marks right? so whats the best way to get rid of them? will they come off in the degreaser tank? im getting the block dipped tommorow
Old Jun 11, 2006 | 08:12 PM
Muckman's Avatar
Moderator in Chief
Default Re: little black marks on cylinder walls? (the.hamburglar)
Have it honed, install new rings.
Old Jun 11, 2006 | 10:37 PM
Default Re: little black marks on cylinder walls? (Muckman)
thats it? anything else?
Old Jun 12, 2006 | 05:25 AM
Muckman's Avatar
Moderator in Chief
might as well install new main bearings while your at it...
Old Jun 12, 2006 | 10:06 PM
rod bearings are at .015. stock specs new are .008-.015. so it falls within the range
Old Jun 13, 2006 | 05:04 AM
oscarmayer's Avatar
the black marks are most likley caused by detonation. you shoudl consider tering the entire motro apart and have it check out for cracks nad stress fracturers. repalce the pistons and rings (hone block to next size up if it tests ok) to be safe.
IF that's the case, but I thin there's a good chance it is.
Old Jun 13, 2006 | 06:27 PM
Default Re: (oscarmayer)
yea it cold be. its completey apart right now. ill chec it out
Aradin
Engine Machining & Assembly
Jul 20, 2015 12:41 AM
4TheLoveOfBoost
Oct 4, 2014 09:48 PM
4TheLoveOfBoost
Aug 31, 2014 07:12 PM
POORMANT
18
Mar 13, 2009 08:22 AM
rdeezy78
Jan 2, 2007 05:11 PM
