idles at 2000+ when cold
Old Jun 11, 2006 | 10:59 AM
Kyles ej1's Avatar
Default idles at 2000+ when cold
ive had this problem for some while now and its getting annoying. when i start my car in the morning or the 1st time during the day it idle at 2000 maybe a nudge more. when i tap the throttle, the rpm moves up a little, sticks there for a slight second then drops back down. its only during warm up, ones its at normal temp it runs like a champ
Old Jun 11, 2006 | 11:16 AM
Shake and Bake's Avatar
My car does the same thing .... i dont think its a problem
Old Jun 11, 2006 | 11:31 AM
slodel's Avatar
Default Re: idles at 2000+ when cold (Kyles ej1)
5600 posts and you dont know that everything idles high when cold or first started up
Old Jun 11, 2006 | 11:37 AM
Kyles ej1's Avatar
Default Re: idles at 2000+ when cold (slodel)
ive never been in a car that ildes at 2k and the rpms stick for a second when you tap on the gas
Old Jun 11, 2006 | 11:44 AM
dps's Avatar
dps
Almost every car idles high when its cold. It's not a problem, its supposed to do that.
Old Jun 11, 2006 | 12:23 PM
JDM B16A's Avatar
Default Re: idles at 2000+ when cold (dps)
When it idle high at first start its fine dude. As long as its okay after your engine is warm and your ECU is run'n on "RAM" memory.
Old Jun 11, 2006 | 01:29 PM
Kyles ej1's Avatar
Default Re: idles at 2000+ when cold (JDM B16A)
well then explain the whole throttle sticking for a second then dropping back down?
and btw im throwing a cel 41 i think
Old Jun 11, 2006 | 02:07 PM
fmrprojects's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 &raquo;</TD></TR><TR><TD CLASS="quote">well then explain the whole throttle sticking for a second then dropping back down?
and btw im throwing a cel 41 i think</TD></TR></TABLE>
thats o2 sensor and it has nothing todo when warming up. the computer ignores the o2 in warm-up cause its in open loop. when the engine is warm then it goes into closed loop and starts using the o2 for fuel delivery. and idling at 2k is normal
Old Jun 11, 2006 | 02:21 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">5600 posts and you dont know that everything idles high when cold or first started up
Since when does post count dictate how much you know? It's not a problem, when any car is cold it will idle high.
Old Jun 11, 2006 | 02:33 PM
swifty4u's Avatar
Default Re: idles at 2000+ when cold (JDM-EJ1)
Most cars I've been in will hold the rpms for like a second when you blip the gas, then drop down low then go to 2000+ rpms if its cold.
Old Jun 11, 2006 | 02:36 PM
JDM-EJ1's Avatar
Default Re: idles at 2000+ when cold (swifty4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swifty4u &raquo;</TD></TR><TR><TD CLASS="quote">Most cars I've been in will hold the rpms for like a second when you blip the gas, then drop down low then go to 2000+ rpms if its cold. </TD></TR></TABLE>
This is what my Accord does.
CoryDHorne
Apr 24, 2014 10:35 AM
sick_dc2
Jul 27, 2008 09:58 PM
hones
Aug 2, 2004 12:44 PM
crx00
Mar 13, 2004 06:39 AM
90-CRXSi
Nov 18, 2002 06:35 PM
