Weird pinging noise?
4dr with z6 head, freshly adjusted valves. the problem is when i shift into a high gear to cruise or at low rpm when i try to accelerate this weird pinging noise happens. and it continues until about 3k rpms. any ideas what it might be?
what block are you using? depending on what block you used for the mini me, the compression might be high and you are pinging. try pumping in 91 octane and retard the timing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">what block are you using? depending on what block you used for the mini me, the compression might be high and you are pinging. try pumping in 91 octane and retard the timing</TD></TR></TABLE>
You are definately detonating. Retard your ignition timing.
kls023
Aug 25, 2009 10:22 AM
Mr.Milton
39
Sep 10, 2007 11:03 AM
eortizr
Aug 12, 2005 01:44 AM
wootcivic
10
Mar 17, 2005 04:57 AM
