LS/VTEC Vtec engages 2 times but then stops
Old Jun 10, 2006 | 05:55 PM
LSracing94's Avatar
Default LS/VTEC Vtec engages 2 times but then stops
i just finally finsihed my LSVTEC..the car will engage into vtec for the first 2 pulls but then stop engaging after that..once the car is shut off and restarted it does the same thing. any ideas what my problem could be?
Old Jun 10, 2006 | 07:17 PM
Dat1BVtecN's Avatar
Default Re: LS/VTEC Vtec engages 2 times but then stops (LSracing94)
adjust the valves maybe
Old Jun 10, 2006 | 11:42 PM
vivid 02's Avatar
Low OIL
Check your oil level .
Old Jun 11, 2006 | 02:47 AM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: LS/VTEC Vtec engages 2 times but then stops (vivid 02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivid 02 &raquo;</TD></TR><TR><TD CLASS="quote">Low OIL
Check your oil level .</TD></TR></TABLE>
also clean your vtec solinoid. VTEC should hit harder when your car is fully warm
Old Jun 11, 2006 | 07:41 AM
LSracing94's Avatar
Default Re: LS/VTEC Vtec engages 2 times but then stops (DC2SIR-G)
the oil isnt low at all, what would adjusting the valves do?
vtec hits hard the first few times..then just completely stops..seems like something electrical more than mechanical
Old Jun 11, 2006 | 08:50 AM
JDMlyfestyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">the oil isnt low at all, what would adjusting the valves do?
vtec hits hard the first few times..then just completely stops..seems like something electrical more than mechanical</TD></TR></TABLE>
Got a vtec controller?
Check all your electrical connections. is vtec built on to the engine harness or did you add it to the harness? check all the pins.
BTW.. in order to Hit vtec you need the following
55 psi of oil pressure
must be going at least 13 mph
water temperature must be at 120* F
Old Jun 11, 2006 | 11:06 AM
RC000E's Avatar
Default Re: LS/VTEC Vtec engages 2 times but then stops (JDMlyfestyle)
VTEC is clearly engaging and then not. What did you do about knock since your running an LS block? Look at the coolant temp sensor also, be sure there are no issues. I am going with knock though, since that is most commonly what I see that leads to your problem.
VTEC should be fairly consistent with temp. Once you get near operating temp vtec will generally stop activating and you should be getting an engine light. You didn't mention it so I am thinking you either already have engine lights your ignoring, or you just failed to mention it. Either way VTEC working after first start, then upon restart points straight to ecu/management related issues....not valves and oil and all that crap.
Actually, maybe valves if it is causing "phantom knock" so to speak, but that's a longshot...Honda knock sensors aren't known for that.
Old Jun 11, 2006 | 12:05 PM
If the vehicle is engaging then not engaging.
If you hit Vtec in 1st or 2nd gear does it follow all the way til redline or does it fall off?
Old Jun 11, 2006 | 02:33 PM
Dat1BVtecN's Avatar
i thought maybe you were experiencing valves float
JSpekBB4
Oct 30, 2007 10:23 PM
hurleyrob
14
Jun 27, 2006 09:51 PM
Lauj87
Jun 28, 2005 11:46 AM
itr1235
Oct 12, 2004 10:56 PM
inzaneN1
Feb 2, 2004 09:24 PM
