2.5" V-band flange.
Does anyone know where I can just buy (1) 2.5" V-band flange for a dp? I did search, couldn't find anything. Also, I wanted to make a 3" dump pipe to switch out at the track. But I have a 2.5" vband setup on the turbo. Will it make a difference if i just use basically a 90 degree 2.5" mandrel bend straight down or will I gain anything from getting some type transition from a 2.5" to 3" dumpipe? thanks for the help
check atpturbo.com, click the catalog.
the default honda-tech answer is that you will gain power.. the real question is if it will be worth making two downpipes.
