HELP! Just built my b16, put timing belt on 3 times, tell me if this is normal..!
I timed the motor like 3 different times putting the timing belt on the correct way, when i slide the crank to TDC right after I time it, the cam gears notches dont match up exaclty (the intake is one tooth higher than exhaust)
i was sure to rotate the crnk 3 teeth /degrees counter clockwise to take up slack, then i torqued tension pulley....
am i doin something wrong???? Marks were lined up before i turned the crank to makeu p for slack... plz tell me this is normal.
i started from cam gears
went around water pump, around tensioner and then around crank, did i do it in the wrong order?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sepulchral »</TD></TR><TR><TD CLASS="quote">i started from cam gears
went around water pump, around tensioner and then around crank, did i do it in the wrong order?</TD></TR></TABLE>
Wrong order!
crank, tensioner, water pump, cam gears.
Wrong order!
4kgst
Sep 15, 2009 01:11 PM
ClubRX
Jul 1, 2007 01:31 PM
