CRV AC bracket not working with swap
Old Jun 7, 2006 | 07:23 PM
ITR EG's Avatar
Default CRV AC bracket not working with swap
Today I received my CRV AC bracket for my b18 in an EG. All 4 bolts like up on the block and the compressor, but the stud that goes into the frame mount sits too hight and i cant get everything lined up to fit, is there some special trick to getting this to work? I know I have the right part and I know a lot of people have used this setup. Help me out guys.
Old Jun 8, 2006 | 06:31 AM
ITR EG's Avatar
Default Re: CRV AC bracket not working with swap (ITR EG)
help me out guys
Old Jun 8, 2006 | 08:46 AM
ralphie14's Avatar
How much to high? You may just have to losen up the upper mount a litte then tighten it back up. Really it depends on how much it needs to move.
Old Jun 8, 2006 | 09:39 AM
ITR EG's Avatar
Default Re: CRV AC bracket not working with swap (ralphie14)
If i get it in the way it sits the frame mount is going to be stretched up maybe an inch. im not too concered about the mount being stretch, i just cant get it all together. thanks a lot for the tip to loosen the top mount, that will probably work, i will give it a shot tomorrow.
Old Jun 8, 2006 | 11:35 AM
ralphie14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR EG &raquo;</TD></TR><TR><TD CLASS="quote">If i get it in the way it sits the frame mount is going to be stretched up maybe an inch. im not too concered about the mount being stretch, i just cant get it all together. thanks a lot for the tip to loosen the top mount, that will probably work, i will give it a shot tomorrow.</TD></TR></TABLE>
Yeah let me know if it helps, I had a few issues getting mine in too, I have a B20 in mine with a P07 brakcet (not sure what that one is) but it took some fanessing.
Old Jun 8, 2006 | 01:21 PM
ITR EG's Avatar
That worked great, thanks a ton. I used a p7j bracket, its nice to finally have AC
prison_snitch
Jun 9, 2006 01:32 PM
rasinhell
Mar 18, 2005 08:45 AM
ill phil
13
Sep 24, 2003 12:56 PM
Dr. Gonzo
Sep 6, 2003 11:10 AM
RyanAutry
Apr 29, 2003 06:27 AM
