what is the Best build for an all motor B18C?
hey guys, im thinking on getting a b18c engine and i was wondering if you can give me an idea on what parts i will be using or adding for a b18c to make it a fast all motor vtec that can run atleast low 13's or less
thanks
thanks
Intake, ITR 4-1header, 2.5" catback exahaust, Port Polish the head, Upgrade cams and cam gears with valve springs and retainers then look to have your ecu chipped/reflashed and have the whole combonation dyno tuned and you should definitly be running in the 13's range. You really should also should upgrade throttle body and intake manifold but if you really want to invest some money look into tuning some Individual Throttle Bodies (ITB's) to your car after you've completely built the head. Am no expert on ITB's though so I'm not sure on all the details there yet.
In the end it all depends on how much money you want to spend. You can go further and upgrade to higher compression pistons, upgrade connecting rods/crank get a lightened flywheel and a typeR tranny with LSD and those will work awsome in conjunction with your all motor build to get you better times. I know the list can go wayyyyyyyyyyyy on this is just what's on top of my head.
to hit low 13's you're going to have to build it internally or just get the hp in a bottle (nos) . i think bottles are for babies, but ehh so what. its going to be alot of money if you want to build it to go that fast and we're talking.
valves
p&p
cams
man im not going to list, pretty much do the most you can with the motor
valves
p&p
cams
Not a cheap hobby any way you look at it that's for sure. All about putting in the time and having the patience and everything pays off. Im pretty sure what I previously posted will be able to get you the times you're looking for
freakie
May 14, 2004 12:25 AM
