Help with balljoint removal from the hub
Old Jun 6, 2006 | 01:03 PM
EG2Driver's Avatar
Default Help with balljoint removal from the hub
Can anyone tell me how to remove the ball joint from this hub? I cannot see the ring i need to remove in order to wack it out. It doesnt have the little holes so i can pull it appart, even behind where the picture cannot show. Can anyone point me in the right direction?
Old Jun 6, 2006 | 01:57 PM
littlegreenb18's Avatar
Default Re: Help with balljoint removal from the hub (DeadEnd9009)
get a ball joint puller, i got mine from autozone for like 10 buck probably 2 years ago, used it on many cars, works great
Old Jun 6, 2006 | 02:09 PM
postman's Avatar
have you tried heat
eK9aT10pSi's Avatar
Default Re: Help with balljoint removal from the hub (littlegreenb18)
wow,just curious, how did you break the threads?
Old Jun 6, 2006 | 02:49 PM
EG2Driver's Avatar
Default Re: Help with balljoint removal from the hub (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">wow,just curious, how did you break the threads?</TD></TR></TABLE>
i cut them off the car because it would spin with the ball joint.
Turns out there was no ring...used a 5 ft bar and a sledge and got the bitch out. The new one slid right in after some hammering. Thanks guys!
Old Jun 6, 2006 | 03:59 PM
court's Avatar
25 Year Member
that thing looks pretty rusted in
Old Jun 6, 2006 | 04:05 PM
schardbody's Avatar
Default Re: Help with balljoint removal from the hub (court)
you have to get the rest of the boot off to get the snapring off then hammer the ball joint out from that side. i have never seen one get stuck so bad a big hammer wouldnt take car of it.
Old Jun 6, 2006 | 06:21 PM
EG2Driver's Avatar
Default Re: Help with balljoint removal from the hub (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">you have to get the rest of the boot off to get the snapring off then hammer the ball joint out from that side. i have never seen one get stuck so bad a big hammer wouldnt take car of it.</TD></TR></TABLE>
sledge hammer had to be employed. Along with a 5 ft pipe that we used as a press. 5 hits and it was out.
Old Jun 6, 2006 | 07:39 PM
spoonracer84eg's Avatar
Nice job I bitched out and took mine to a machine shop. $20 for both to be pressed out and new ones pressed in
Old Jun 6, 2006 | 08:50 PM
EG2Driver's Avatar
Default Re: Help with balljoint removal from the hub (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">Nice job I bitched out and took mine to a machine shop. $20 for both to be pressed out and new ones pressed in </TD></TR></TABLE>
mine was done for free. A shop said it'd be 200 bucks to get everything done, with labor. 65 for the balljoint alone. i paid 27 for it at autozone.....
DIY FTW!!!!!!!!!!!!
ZOMBIEKILLER
Suspension & Brakes
11
Feb 24, 2008 05:51 PM
damn_import_culture
19
Apr 28, 2007 08:34 AM
gRim06
Apr 21, 2007 09:01 PM
Nocturnal
Aug 7, 2005 08:44 PM
gumbybum
Jan 31, 2003 11:11 AM
