GSR Brake conversion problem
I got the brakes on my car and had blead the brakes but when the car starts there is no pressure from the pedel. Also i hear a slight fient squeaking sound in the rear right and the left front brake doesnt turn when I put it in first. does anyone know what's wrong with it?
Re: GSR Brake conversion problem (BlueIntegraBoy)
the car is stationary, and i hear a slight squeaking noise or maybe somethings loose in the rear. but bleeding the brakes shouldn't take that long should it? also should i bleed the mastercylinder? the ebrake cable i found out today i need to get the civic si EG model cable to connect it with the gsr rear disc brakes.
Re: (pdiggitydogg)
no im using the stock CX master cylinder. It brakes fine i guess but could be better. do i need to upgrade it to the gsr master cylinder? I finally got da rite freakin ebrake cable for my car today, YES!! i can drive with no worries now lolz. man i swear firestone suck! they dunt know how to do an alinement on a lowered car wut kinda sh*t is tat??o and also how can u tell if it is a GSR rear disc brake? the caliper's piston has like a cross shape in the middle rite? and also does SiR uses GSR brakes? because the shop that i got it from said the front n rear was from a SiR but the caliper size n rotor size is a GSR
Modified by EG-tofu at 10:53 PM 6/6/2006
Modified by EG-tofu at 10:55 PM 6/6/2006
