Swap question????????????/
Old Jun 6, 2006 | 11:52 AM
Shake and Bake's Avatar
Default Swap question????????????/
I am in the process of doing my swap and the shop that is doing it for me wans to know if i should replace the water pump and timing belt now. He didnt even look at it yet and says that its theres a really good chance that the water pump is rotted. I told him that the motor averages 35,000 miles and it should still be fresh. He wants to charge me $350 total including labor for a new timing belt and water pump. Do you think its worth it to have this done now even though there is a chance that there could be nothing wrong with either one? And he says i should replace the clutch.
Comments please.....
Old Jun 6, 2006 | 11:54 AM
tsdenny's Avatar
Default Re: Swap question????????????/ (AllstockSIke)
its a good idea to replace the timming belt and water pump
i would
Old Jun 6, 2006 | 11:56 AM
Fallen86's Avatar
Default Re: Swap question????????????/ (void_accord)
not too hard to just do it yourself afterwards tho...and a lot cheaper. just my opinion.
Old Jun 6, 2006 | 12:03 PM
tatmark1's Avatar
Default Re: Swap question????????????/ (Fallen86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fallen86 &raquo;</TD></TR><TR><TD CLASS="quote">not too hard to just do it yourself afterwards tho...and a lot cheaper. just my opinion.</TD></TR></TABLE>
Old Jun 6, 2006 | 12:23 PM
Anyone else?
Old Jun 6, 2006 | 12:46 PM
Syndacate's Avatar
get it back from the garage and do it urself, I'm dead serious, it's important that it needs to be chagned, it could have sat for awhile, on the flipside, that's an assload for taht job, u can do it urself, trust me on this, it'll take u a few hours TOPS if u've NEVER done it b4
Old Jun 6, 2006 | 12:51 PM
ctr status's Avatar
Yeah, i changed my water pump and timing belts when i got my swap and my motor had low milage on it. As for clutch, go ahead and get yourself a nice exedy organic.
Old Jun 6, 2006 | 01:09 PM
Ok, so when i get it back how can i find out if the water pump is bad? Or should i just replace it no matter what?
Old Jun 6, 2006 | 01:43 PM
Default Re: (AllstockSIke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllstockSIke &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so when i get it back how can i find out if the water pump is bad? Or should i just replace it no matter what?</TD></TR></TABLE>
bump
Old Jun 6, 2006 | 02:08 PM
92Hizzle's Avatar
like the guys said, replace the water pump and timing belt no matter what. Those parts are fairly cheap and it would be a shame to screw up a nice new motor because a $40 part broke on you. Also, I would grab a new clutch, just because if I did a swap I would want it done the best it could be, but you may be able to get by on the stock clutch for a while id the motor does infact have the milage they claim it does.
Old Jun 6, 2006 | 07:11 PM
Syndacate's Avatar
Default Re: (92Hizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Hizzle &raquo;</TD></TR><TR><TD CLASS="quote">like the guys said, replace the water pump and timing belt no matter what. Those parts are fairly cheap and it would be a shame to screw up a nice new motor because a $40 part broke on you. Also, I would grab a new clutch, just because if I did a swap I would want it done the best it could be, but you may be able to get by on the stock clutch for a while id the motor does infact have the milage they claim it does.</TD></TR></TABLE>
Old Jun 7, 2006 | 05:47 PM
Kiid's Avatar
Default Re: Swap question????????????/ (AllmotaBseries)
replace the timing belt and water pump
id3379
Mar 22, 2008 09:59 PM
VtecPMP
Aug 13, 2005 03:20 AM
antondaz
Sep 6, 2004 07:22 PM
808State
Apr 8, 2004 11:48 AM
RussHondaCRXVtec
Aug 20, 2003 02:42 PM
