High Idle Problem
Old Jun 5, 2006 | 04:39 PM
aakeobo's Avatar
Default High Idle Problem
I have done numberous searches and nothing has helped. I have a 99 GSR. The car idles real high with the idle screw all the way in, around 1500 sometimes 2000. It does NOT flucuate. I checked the voltage on the TPS and its within spec. I've checked the IACV and its fine.
With the idle screw all the way in, I placed my thumb over the bypass passage on the throttle body and the car dies. Therefore I don't think theres a vacuum leak. Am I wrong?
Does anyone know what the problem could be?
Also, I recently discovered that there is a crack on my radiator. I dont know if the crack came before or after the idle problem. Could this also contribute?
Old Jun 5, 2006 | 05:43 PM
teamredline9k's Avatar
Default Re: High Idle Problem (aakeobo)
my personal idea of what it is is a vaccum line if u need help findin if it is a vaccum leak u can spray carb cleaner or somethin on ur lines and see if they leak if they leak it will be bubbling so hope u find out whats wrong later
Old Jun 5, 2006 | 07:39 PM
redface's Avatar
Default Re: High Idle Problem (teamredline9k)
low coolant will cause a poor idle speratic or high usaully so yes if your radiator is cracked and its losing coolant this could be your problem so check your coolant hope this helps
Old Jun 6, 2006 | 06:31 AM
aakeobo's Avatar
Old Jun 6, 2006 | 06:40 AM
aakeobo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamredline9k &raquo;</TD></TR><TR><TD CLASS="quote">my personal idea of what it is is a vaccum line if u need help findin if it is a vaccum leak u can spray carb cleaner or somethin on ur lines and see if they leak if they leak it will be bubbling so hope u find out whats wrong later</TD></TR></TABLE>I've tried that. I couldn't find anything.
Old Jun 6, 2006 | 06:55 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redface &raquo;</TD></TR><TR><TD CLASS="quote">low coolant will cause a poor idle speratic or high usaully so yes if your radiator is cracked and its losing coolant this could be your problem so check your coolant hope this helps</TD></TR></TABLE>
if there is any air in the radiator it could also cause this. Have you taken off your throtte body at anytime? Or it maybe time to change your TB gasket. If it isnt the sensors then it has to be a vacuum leak.
Old Jun 6, 2006 | 09:31 AM
aakeobo's Avatar
I have taken it off the throttle body. I didnt change the gasket but it did drive fine until I drove it hard. Then it started to idle real high.
Modified by aakeobo at 12:51 PM 6/6/2006
Old Jun 6, 2006 | 03:31 PM
Default Re: (aakeobo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aakeobo &raquo;</TD></TR><TR><TD CLASS="quote">I have taken it off the throttle body. I didnt change the gasket but it did drive fine until I drove it hard. Then it started to idle real high.
Modified by aakeobo at 12:51 PM 6/6/2006</TD></TR></TABLE>
i think that is your problem there. When you take off the throttle body most of the time the paper gasket will in some way be deformed. Try changing the gasket I'm pretty sure that is the problem. I know from experience.
Old Jun 7, 2006 | 05:15 AM
aakeobo's Avatar
Default Re: (JDM knowledge)
Ill give that a try Thursday.
Old Jun 7, 2006 | 05:25 AM
realis9's Avatar
check your timing. Maybe the gear jump a tooth. That what happen to me.
Old Jun 7, 2006 | 07:58 AM
Default Re: (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">check your timing. Maybe the gear jump a tooth. That what happen to me. </TD></TR></TABLE>^^ that too.
PROJECT 91
Sep 25, 2009 11:18 AM
averyvm
17
Jan 17, 2007 11:51 AM
R. Mack
Jun 1, 2005 07:55 PM
kihun_cha
20
Sep 17, 2004 03:18 PM
