DC2 Radiator = Fit on EG ?
Old Jun 5, 2006 | 03:26 PM
sleeper101's Avatar
Default DC2 Radiator = Fit on EG ?
does DC2 94-01 Integra stock radiator will fit on 92-95 Civic ?
how to make it fit ( no weld) ? is it worth the effort ( bigger radiator)
Thanks alot
Old Jun 5, 2006 | 04:26 PM
ITR EG's Avatar
Default Re: DC2 Radiator = Fit on EG ? (sleeper101)
i've seen it done a ton of times, not sure how, but im sure its pretty straight forward. If you are doing it because of a swap i went with the del sol vtec rad, its a dual core and bolts right in place of the civic rad. If you dont have a swap there is no point to changing rads
Old Jun 5, 2006 | 04:48 PM
sleeper101's Avatar
Default Re: DC2 Radiator = Fit on EG ? (ITR EG)
how to determine if its : dual core ( del sol vtec) ?
is there any # or marks / shapes on it ?
Thanks
Old Jun 5, 2006 | 05:07 PM
EGRhatch's Avatar
it looks thicker, like 2in vs 1in just make sure you have the bracket for it to sit on on the driverside of the radiator support. everythign else should be straight forward
Old Jun 5, 2006 | 05:14 PM
EJ1_203's Avatar
Default Re: DC2 Radiator = Fit on EG ? (EGRhatch)
the teg rad fits. but u need 2 re- weld the bracket on the bottom. and make custom bracket for the top to hold the radiator in place. or you could just got with a stock em1 rad like me
CRVTEC0WNZJ00
Oct 16, 2005 10:00 AM
MugenT
Jun 3, 2005 03:23 PM
neeks
Feb 14, 2005 01:43 PM
GWInquisitor14
Dec 6, 2004 02:42 PM
cheezemaster
Apr 27, 2001 11:35 AM
