DC2 Radiator = Fit on EG ?
does DC2 94-01 Integra stock radiator will fit on 92-95 Civic ?
how to make it fit ( no weld) ? is it worth the effort ( bigger radiator)
Thanks alot
Thanks alot
Re: DC2 Radiator = Fit on EG ? (sleeper101)
i've seen it done a ton of times, not sure how, but im sure its pretty straight forward. If you are doing it because of a swap i went with the del sol vtec rad, its a dual core and bolts right in place of the civic rad. If you dont have a swap there is no point to changing rads
it looks thicker, like 2in vs 1in just make sure you have the bracket for it to sit on on the driverside of the radiator support. everythign else should be straight forward
Re: DC2 Radiator = Fit on EG ? (EGRhatch)
the teg rad fits. but u need 2 re- weld the bracket on the bottom. and make custom bracket for the top to hold the radiator in place. or you could just got with a stock em1 rad like me
