Disassembling Motor?
Old Jun 5, 2006 | 10:28 AM
Flava's Avatar
Default Disassembling Motor?
I want to part out my gsr motor and b16 longblock and was wondering how you go about taking the head and tranny from the block, etc.
Old Jun 5, 2006 | 10:32 AM
cyang08's Avatar
go buy a helms manual or any manual that teaches how to fix the year and make of the car that the motor is from.
Old Jun 5, 2006 | 10:34 AM
Flava's Avatar
Default Re: (cyang08)
would it be the same for pretty much any b-series motor?
Old Jun 5, 2006 | 10:38 AM
Toyo TI-S Spec's Avatar
Default Re: (dingy)
You have to remove the bolts in a certain patern so you don't damage the head but its even more important when you put it on so that everything is even. I believe you can find the info if you search around or try a service manual. Its pretty easy.
Old Jun 5, 2006 | 10:39 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Toyo Proxes RA-1 Rubber)
You really think people are going to want stock internals? You would make fine money selling the engine's complete.
Old Jun 5, 2006 | 10:45 AM
Flava's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">You really think people are going to want stock internals? You would make fine money selling the engine's complete. </TD></TR></TABLE>
No I want to sell the complete head, block, and tranny seprate. Not the internals. No one seems to want it complete local and shipping is a PITA for it complete.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toyo Proxes RA-1 Rubber &raquo;</TD></TR><TR><TD CLASS="quote">You have to remove the bolts in a certain patern so you don't damage the head but its even more important when you put it on so that everything is even. I believe you can find the info if you search around or try a service manual. Its pretty easy. </TD></TR></TABLE>
I think my friend has a helms for 96-00 civics.
Old Jun 5, 2006 | 10:48 AM
Default Re: (dingy)
Should be almost the same pattern. Its just done to make sure nothing is stripped and bent etc. If I was local I'd probably pick it up . You should keep it and build it unless you are in need of money.
Old Jun 5, 2006 | 10:49 AM
Flava's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toyo Proxes RA-1 Rubber &raquo;</TD></TR><TR><TD CLASS="quote">Should be almost the same pattern. Its just done to make sure nothing is stripped and bent etc. If I was local I'd probably pick it up . You should keep it and build it unless you are in need of money.</TD></TR></TABLE>
I need the money. I'm keeping the gsr but just putting the b16 head on it and maybe the tranny also and just selling the rest.
Y3P3L3
May 24, 2010 01:48 PM
SlowB16
21
Jun 17, 2008 06:47 PM
hondachris1994
26
Jan 22, 2007 06:29 PM
Flava
Jun 5, 2006 02:14 PM
god.loves.ugly
Apr 15, 2006 06:12 PM
