Disassembling Motor?
Re: (dingy)
You have to remove the bolts in a certain patern so you don't damage the head but its even more important when you put it on so that everything is even. I believe you can find the info if you search around or try a service manual. Its pretty easy.
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">You really think people are going to want stock internals? You would make fine money selling the engine's complete. </TD></TR></TABLE>
No I want to sell the complete head, block, and tranny seprate. Not the internals. No one seems to want it complete local and shipping is a PITA for it complete.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toyo Proxes RA-1 Rubber »</TD></TR><TR><TD CLASS="quote">You have to remove the bolts in a certain patern so you don't damage the head but its even more important when you put it on so that everything is even. I believe you can find the info if you search around or try a service manual. Its pretty easy. </TD></TR></TABLE>
I think my friend has a helms for 96-00 civics.
Re: (dingy)
Should be almost the same pattern. Its just done to make sure nothing is stripped and bent etc. If I was local I'd probably pick it up . You should keep it and build it unless you are in need of money.
Re: (Toyo Proxes RA-1 Rubber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toyo Proxes RA-1 Rubber »</TD></TR><TR><TD CLASS="quote">Should be almost the same pattern. Its just done to make sure nothing is stripped and bent etc. If I was local I'd probably pick it up . You should keep it and build it unless you are in need of money.</TD></TR></TABLE>
I need the money. I'm keeping the gsr but just putting the b16 head on it and maybe the tranny also and just selling the rest.
SlowB16
21
06-17-2008 06:47 PM
