Squeaking coming from front wheels....
I got a weird squeaking noise coming from my front wheels... it occurs in rotation with the wheel, as i speed up and slow down so does the "rate" of squeaking. I just replaced my tie rod ends, upper and lower ball joints and upper control arms with all new OEM equipment. I also replaced both axles with new ones. So im not sure what it could be, pads? wheel bearings? Seems to be coming from both sides.
If i press teh brake pedal slightly (before there is good pressure) the noise goes away, and it comes back when i release the brake. If i press the brakes hard the pads dont squeal at all, hawk hps pads. It happens just driving straight.
Any ideas? Maybe I just need to grease something?
it just sounds like u need new brakepadss and a good resurfacing... it's the lil metal indicator scratching ur rotor telling u ur brakes are almost gone
edit:: check it soon; if it is ur brake pads, replace it soon, its gonna eat away ur rotor and then ur gonna have to get a new one...
yeah i thought thats what it was but i would think they would squeak even MORE when i slam the brakes if that were the case but the squeakin goes away when i hit the brakes....
If you replaced all the suspenstion related pieces and nothing is bent (no accidents) and it only squeeks and a certain point, then your rotors are likely warped.
Solution, replace the rotors, 15 bucks each for blanks at pepboys. I would replace the pads as well, since they are probably not worn down flat.
when i had my legend and was stupid... it did the same thing.. i just rode on it... it effed up my rotor pretty bad... but it was just brake pads..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">yeah i thought thats what it was but i would think they would squeak even MORE when i slam the brakes if that were the case but the squeakin goes away when i hit the brakes....</TD></TR></TABLE>
thats what i thought too... but i just ended up changing the brake pads and resurfacing the rotors... it went bacc to normal... when i got my civic it started to do the same thing... i knew what i had to do...
pull the wheel off and tell us what u see!
Modified by bpkmrtoes at 3:37 PM 6/4/2006
ok ill replace the pads and rotors thats simple, i think the rotors are warped cause i get some vibration stopping too when im slowing down from high speeds.... how do you prevent warpage?
Also my upper control arms are a lil squeaky (but not like the wheels) what kinda grease can i use to quiet them down? like wd40 or white lithium?
if u get vibrations then it's warping too... try not to brake too hard... and i think.. riding the brakes do too... not sure... but if u drive hard then come home to wash ur car and use a water hose to spray the wheels might cause it to warp...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 »</TD></TR><TR><TD CLASS="quote">Backing plate. Your welcome</TD></TR></TABLE>
?? you mean the dust cover or the ring behind the bearing? Its def. not the dust cover... not sure how the bearing ring thing could squeak
Android
Aug 20, 2002 04:40 PM
