VAFC owners reply need your opinions !
Old Jun 4, 2006 | 06:21 AM
Vtecme92's Avatar
Default VAFC owners reply need your opinions !
I have bought a VAFC for about 6 months now however have not had the chance to have someone put it in, now what I want to know is the people that actually used one is it better running with a VAFC then not running one at all; or running one without the proper tunning will make your car lose power? I have heard alot of bad things about the VAFC but I have no personal experience or anyone close to me using one so I need opinions. IF both cars for have a gsr swap (same setup) in them I always thought that the car having a VAFC and the proper tunning would be better (more horse and run better) then the one that doesn't have one; am I wrong?
Old Jun 4, 2006 | 06:29 AM
mr.beeks's Avatar
Default Re: VAFC owners reply need your opinions ! (Vtecme92)
spend a couple of hours @ dyno fine tuning it...
and I was pleased with the results...
I felt the difference after..
Old Jun 4, 2006 | 10:54 AM
1turbodc2's Avatar
no 2 engines are a like, VAFC is okay, i would spring for crome pro, or something around that nature depending on your mods.. VAFC all it does is trick the map sensor so if u have an 0bd2b car it will learn around it and go back to stock settings. what obd is the car? and what mods do u have that warrent needing some sort of piggy back computer?
Old Jun 4, 2006 | 10:57 AM
lVlemphizStylez's Avatar
Default Re: (1turbodc2)
piggybacks FTL
Old Jun 4, 2006 | 12:22 PM
Vtecme92's Avatar
Default Re: (lVlemphizStylez)
Here are my mods; B16A block with tpye r pistons, gsr head with itr cams, dc header, skunk 2 intake manifold, p72 ecu. I know there are other better things like the honda data but want to know if I should at the very least go install and tune my car with a my VAFC since I already have it, will I see some increase in horse power?
Old Jun 4, 2006 | 12:24 PM
Default Re: (Vtecme92)
so lemme ask you...why pay to get a shitty piggyback tune...only to go back all over again and get it tuned properly with a rom editor/burner...crome is free...crome pro is inexpensive...youll spend more getting it tuned twice than just doing it right the first time
Old Jun 4, 2006 | 12:43 PM
Vtecme92's Avatar
My question is should I put in my VAFC since I already have it will my car be better then it is right now without it, I don't care about tunning it twice I want to try the different setups to see the difference cause I will sooner or later change some mods to the engine....
Old Jun 4, 2006 | 12:44 PM
if you insist on wasting your money...yes you can tune it with the VAFC...will it make more gains over tuning it with a rom editor??? nowhere near it...
typesguy
Sep 30, 2005 12:27 PM
LoseRPunKx182
Jul 13, 2005 03:34 PM
spooned out
Aug 25, 2003 06:31 PM
ITR 01-0840
Jan 7, 2002 04:59 PM
