What Causes Knock ????!!
Old Apr 14, 2002 | 08:36 PM
Chris_'s Avatar
Default What Causes Knock ????!!
My engine is throwing A knock sensor code and I can't figure it out.
What causes knock what should I check or replace????
I have already checked the plugs and replaced the plug wires. got new gas. checked all wiring and what not. what next!
BTW it's a B16a
Old Apr 14, 2002 | 09:01 PM
rioninja's Avatar
Default Re: What Causes Knock ????!! (crxconnection)
Did you just swap in the B16a? and did you run a wire for the knock sensor?
(its the single prong sensor on the back of the block, just above and left of the oil filter).
Old Apr 14, 2002 | 10:20 PM
the DR.'s Avatar
Default Re: What Causes Knock ????!! (RioNinja)
only thing right off the top of my head would be that you should only put in 91 octane or higher if its a b16, and maybe check your timing.
anyone else?
Chris_'s Avatar
the engine has been in my car and running smooth for 6 months
I only run premuim in my car but I think its the gas
knock can only be caused by 4 things
1.bad gas
2.an inoperative EGR valve (code 12)
3.buildup of carbon in the combustion chamber
4.over advanced timing
[Modified by crxconnection, 2:25 AM 4/15/2002]
JK-EP3
Jan 17, 2013 09:56 AM
hotxcivic92
13
Nov 4, 2007 06:52 PM
Fardoche
Jul 31, 2003 10:29 PM
SteelCityKid
Apr 16, 2002 10:32 AM
tysir
Jul 31, 2001 06:54 PM
