Coolant Problem!
I have a coolant problem.. I put engine coolant in about a day ago, i come back the next day and its gone.. i don't think its leaking, i did see a little smoke coming from it once but didnt look like anything serious, but the engine is running a little hot.. any suggetsion
You need a spark plug socket a ratchet extension and a compression tester..go find one at autozone or something. Make sure your engine is warm...remove the sprak plugs, and the ECM fuse. have someone hold the compression tester while you go in your car and crank the engine over til you get a solid reading on all 4 cylinders.
Marcus Coker
Jun 26, 2015 06:01 AM
