broken injector (plastic piece)
Old Jun 2, 2006 | 06:39 AM
No_Fear's Avatar
Default broken injector (plastic piece)
an injector broke the plastic part of it(pic above),is it going to work ok?
Old Jun 2, 2006 | 12:57 PM
devnull's Avatar
It may "work". The plastic, if I remember correctly, protects the injector pluse. It may drip though cause that cylinder to run rich. I would replace it just to be sure.
Old Jun 3, 2006 | 07:29 AM
No_Fear's Avatar
ok,thank you
Old Jun 3, 2006 | 10:45 PM
themorphious's Avatar
it's called a pintle cap and it is used to protect the needle in the end of the injector from building up with carbon. it's not NECESSARY, but i'd look into gettting the injectors you have flow tested and new o-rings and stuff on them. a good rebuild will replace ALL the pintle caps. i guess it just depends on who you get to rebuild them...
Old Jun 4, 2006 | 01:51 AM
No_Fear's Avatar
Default Re: (themorphious)
we thought it was helping the flow that plastic,we install it temprary and going to replace it,tomorrow.
HondaHeddie
Nov 26, 2008 10:44 AM
JayFI
Sep 30, 2004 07:22 AM
Casey
Feb 16, 2004 03:58 PM
10seceg
Jan 1, 2004 02:46 PM
1.8Tities
Apr 22, 2003 11:37 AM
