car bucking
Old Jun 1, 2006 | 06:45 PM
mtownsi's Avatar
Default car bucking
wats god i have a 99 si i/h/e b16. it has 98000 miles on it. 2 days ago it started bucking wen i hit the gas it bucks hard. could it be the fuel filter i havnt changed it since i bought it and i bought it wit 92000 on it. o and my valve adjustment is all fucked up that im gonna be fixing in 2 days. iight thanks
Old Jun 1, 2006 | 07:27 PM
Schrader's Avatar
Codes? Maintence. . . .
Old Jun 1, 2006 | 08:11 PM
mtownsi's Avatar
no codes just changed oil,timingbelt,s/c,p/s beltsspark plugs are good ngks, wires are good msd8.5mm, havnt looked the distributoryet
Old Jun 2, 2006 | 08:38 AM
eg8civic93's Avatar
Default Re: car bucking (mtownsi)
my guess would be your fuel filter. Check your entire fuel supply, from filter, pump and output.
Old Jun 2, 2006 | 10:25 AM
EF8IGHT's Avatar
Default Re: car bucking (eg8civic93)
BUCKING AND SURGING IS MOSTLIKELY A PROBLEM WIH THE IGNITION SYSTEM
I START WITH THINGS RELAED TO SPARK AND TIMING
Old Jun 2, 2006 | 10:36 AM
fmrprojects's Avatar
Default Re: car bucking (EF8IGHT)
you sure when you did the timiing belt that all the marks lined up. put a timing gun on it and see if its in spec. if alls that is good then check the ignitor in the distributor, a bad ignitor will cause a engine to misfire
Old Jun 2, 2006 | 10:40 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8civic93 &raquo;</TD></TR><TR><TD CLASS="quote">my guess would be your fuel filter. Check your entire fuel supply, from filter, pump and output.</TD></TR></TABLE>
The problem you describe sounds a lot like fuel starvation Change the fuel filter reff to the shop manual for locations on the car there are normally 2 filters one by the gas tank under the car and one mounted on the fire wall. Always change both at the same time.
Old Jun 2, 2006 | 10:44 AM
screech's Avatar
Default Re: car bucking (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote"> a bad ignitor will cause a engine to misfire</TD></TR></TABLE>
but misfiring should cause a CEL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtownsi &raquo;</TD></TR><TR><TD CLASS="quote">no codes just changed oil,timingbelt,s/c,p/s beltsspark plugs are good ngks, wires are good msd8.5mm, havnt looked the distributoryet </TD></TR></TABLE>
same thing happened with me and i would say deff change your fuel filter it fixed my prob
Old Jun 2, 2006 | 11:01 AM
nutball72's Avatar
if all else fails check the o2 sensor when that goes its starts stuttering
Old Jun 3, 2006 | 07:14 PM
mtownsi's Avatar
ok ima try the fuel filter because the the timing is perfect and the ignition system if good. thanks for all ur help ill let u know wat it is
capm.stabahoe
Dec 27, 2008 06:17 PM
S2k Hybrid
12
Apr 24, 2007 09:41 PM
dragaholic
Feb 23, 2007 11:05 PM
pr_tony_montana
May 27, 2005 01:09 AM
civicspeed77
May 27, 2003 12:13 PM
