SRS Light on, no horn, no cruise control...
Old Jun 1, 2006 | 12:08 PM
boricuacvc's Avatar
Default SRS Light on, no horn, no cruise control...
ok. got the car bought a year ago. about 2 months ago, the SRS light turned on for no reason since nothing was done to the car. at the same time, i lost my cruise control as well as the horn.
first solution was to check fuses... all good and nothing.
second solution was to change the SRS unit... did that and nothing.
as a third solution, i was told it could the the clock spring in the steering column since that would be the only reason why all 3 things would cut out... i ordered the part for cheap, but dont wanna go through the trouble for nothing.
do you guys have any experience or any ideas on what it could be? honda is charging $95 just to diagnose... and for that, i might as well spend it on the solution.
thanx
Old Jun 1, 2006 | 10:25 PM
HONCORD's Avatar
Default Re: SRS Light on, no horn, no cruise control... (boricuacvc)
Im sure thats the clock spring. If all that happened at the same time. Cuz if you thing all of that ties up in one thing.
Old Jun 2, 2006 | 05:49 AM
vietherbs's Avatar
yeah that has to be. i just installed a euro-r steering wheel the other day. the clock spring does wire those three things. if this helps....the airbag is a complete separate wire. and the horn's connected to the cruise control. basically. no cruise control. no horn. i learned that this week. its kinda stupid. lol. but my best bet is the clock spring. i say go to a junk yard and part it out! lol
Old Jun 2, 2006 | 02:14 PM
pumafeet10's Avatar
Default Re: (vietherbs)
not sure what the clock spring is but there is a cable reel that went bad on mine and that was the culprit with the horn and cc not working so that was the fix. not a cheap part but def fixable
ALL-OUT
11
Aug 29, 2010 07:29 PM
Rob_KCMO
Apr 21, 2010 08:33 AM
Jdmb16sir2
Apr 2, 2007 06:21 PM
O RLY
Oct 19, 2006 08:01 PM
undercoversi
Oct 27, 2004 03:35 PM
