So is it time for new rings and tune?
Old May 31, 2006 | 07:42 PM
dangerranger21's Avatar
Default So is it time for new rings and tune?
SO yah my car was just smoking like crazy today like a chimney, it is running real rich and im pretty sure the rings are gone! everything else is mechanically sound but its just barreling out smoke like a chimney and running rich, i figure its time to slap some new rings in and get it tuned again.. Sound about right?
Old May 31, 2006 | 08:16 PM
Default Re: So is it time for new rings and tune? (dangerranger21)
anyone??
Old May 31, 2006 | 08:39 PM
teg racer 877's Avatar
do compression and leak down tests, dont jump to conclusions, could be anything.
Old May 31, 2006 | 08:57 PM
RCautoworks's Avatar
Why is it running rich ? Was it ever tuned ? Do a leak down and compression test.
Old May 31, 2006 | 09:04 PM
It was tuned and tuned good too! its just puffin smoke like no other and out of the breather tube which im going to have to do somthing about that too I think it was time tho that the rings had to go so i will end up replacing those with a new headgasket
Old Jun 1, 2006 | 09:51 AM
oscarmayer's Avatar
before you rip it appart, do exactly what they suggested. go to the auto store spend $25 and get a compression tester. test the compression via the following
unscrew all sparkplugs,
pull the fuel pump fuse
screw the tester
sitin the car and put the pedal to the floor
crank the engine over via the key for about 10-15 seconds. now go look at the reading.
Write them down and what cyclinder they are.
when done post your results to get more info.
Old Jun 1, 2006 | 09:58 AM
adseguy's Avatar
Default Re: (dangerranger21)
The ringlands might be shot also. That requires getting a whole new piston
Old Jun 1, 2006 | 10:01 AM
B18 CYA's Avatar
black or blue smoke?
Old Jun 1, 2006 | 10:33 AM
Finland's Avatar
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">The ringlands might be shot also. That requires getting a whole new piston</TD></TR></TABLE>
Old Jun 1, 2006 | 11:11 AM
notoriousB's Avatar
that's far more likely than just the rings. good luck, if that's what it is it's time for some forged pistons! but like everyone said do a compression and leakdown test to pinpoint the problem first.
Old Jun 1, 2006 | 11:19 AM
Soccerking3000's Avatar
Default Re: (notoriousB)
yea i bet you broke some ringlands, when my car started burning blue smoke i didnt even do a compression check and just tore it apart cause i knew something bad happened lol
Old Jun 4, 2006 | 11:55 AM
Default Re: (Soccerking3000)
well I took it apart and it was the ring lands so tomarrow I am ordering some CP pistons with a bunch of other goodies, so the motor will be freshened up!
GTEater
Sep 30, 2010 09:43 PM
pizzamanprelude
Sep 28, 2006 10:51 AM
allmotorsi04
Apr 1, 2006 05:08 PM
silverboost
Nov 8, 2005 01:01 PM
1fastdc2
Jan 5, 2003 07:47 AM
