NO Spark......??????
Old May 31, 2006 | 01:31 PM
1BAD347's Avatar
Default NO Spark......??????
Ive searched all over this board and others also. Everyone seems to lean towards the same parts, but nothing is fixing my problem.
I have swapped the ign coil and the ICM but still will only crank and NOT start.
Any more suggestions?
BTW: 2000 Civic EX
Modified by 1BAD347 at 6:02 PM 5/31/2006
Old May 31, 2006 | 01:36 PM
crxnj's Avatar
Default Re: NO Spark......?????? (1BAD347)
have you changed the cap and rotor as well? is the check engine light on? are you getting fuel ?
Old May 31, 2006 | 01:44 PM
crxnj's Avatar
Default Re: (1BAD347)
obd2 scanner ? is the car obd2?
Old May 31, 2006 | 01:50 PM
mickiemagik's Avatar
Change cap and rotor, and check the main relay
Old May 31, 2006 | 02:05 PM
crxnj's Avatar
i doubt its the main relay since you're getting fuel ..also for more answers post your question herehttps://honda-tech.com/zeroforum/1 ,,since its now in the pre 91 section
Old May 31, 2006 | 06:40 PM
1BAD347's Avatar
It ended up being a bad coil. I even had a bad coil from a buddy of mine. Bought a new one, now its running good.
Thanks for the suggestions.
the soL that could
15
Aug 27, 2011 06:44 PM
revhardallday
Nov 28, 2008 10:10 AM
live_again_integra
Jan 4, 2007 05:42 PM
O16581724 5 2 5
Mar 9, 2006 10:32 PM
h2392si
Apr 13, 2003 11:28 AM
