spark problem
spark problem
hey i been having this problem with my car..
start it up and drive around for more then 15 mins car will just shut off, then i try to start it and it just cranks... i have fuel pressure... let the car sit for 30 mins then it will start up but when it gets warm it dies.....
so then i replace the coil/module inside the distributer and it seem like it worked i drove the car for 4 days and it never died... now its doing the same thing again... i have a new coil/moduel new plugs new wires and a new cap and rotor...... im thinking the distributer it self might be bad...
any info will be appriciated.... thnaks
To eliminate the main relay so you can keep going forward in your diagnosis efforts, do the check given at http://www.tegger.com/hondafaq/start...html#mainrelay.
Are your new ignition parts OEM?
If you messed with the new coil much, it is possible it is already damaged. Check it per http://www.tegger.com/hondafaq/start...s.html#badcoil
Are there any engine codes?
live_again_integra
01-04-2007 05:42 PM
