change cap/rotor vehicle will not start
Old 08-18-2011, 11:41 AM
the soL that could's Avatar
Icon6 change cap/rotor vehicle will not start
ok... i did everything accordingly, and the car ran for about 5 minutes. i drove it to the trash can and it died. now, it will not start up.
i dabbed a bit of PB blaster on the rotor screw to remove... there is no sign of moisture. what i think happened is, i bent the ignition coil spring when i put back on the cap...
my car is blocking the trash... people are getting angry~!
UP AND RUNNING... WAS MY IGNITION COIL.
Old 08-18-2011, 11:44 AM
Former User's Avatar
Default Re: change cap/rotor vehicle will not start
Push the car away so it's not blocking anything and then test for spark and fuel. You may have blown the coil.
Old 08-18-2011, 11:56 AM
Linked's Avatar
check your order of spark plugs, i don't have a diagram though
Old 08-18-2011, 12:06 PM
it was idling for about 10 minutes...
i have no tools to check for spark/fuel... =/ need to walk to the autoparts store.
Old 08-18-2011, 12:08 PM
Originally Posted by the soL that could
it was idling bot about 10 minutes...
i have no tools to check for spark/fuel... =/ what to buy?
Fuel - no tools needs
Turn key from off to ON(II). Do you hear the low humming noise of the fuel pump priming for 2 seconds.
Spark - need spare spark plug and buddy
Click spark link in my signature.
Old 08-18-2011, 12:19 PM
green91's Avatar
the screw on the rotor probably backed out.
Old 08-18-2011, 12:37 PM
i removed the cap and the screw is still there... from what i understand, it will work with or without the screw. some autoparts stores sell it "push and play".
RONJ... i have fuel... i can hear the fuel pump prime.
what happens when i DO NOT get spark?
Old 08-18-2011, 12:40 PM
What car?
If you don't have spark, check whether the timing belt snapped and test the resistances of the coil (see FAQs sticky).
Old 08-18-2011, 01:00 PM
Kenshiro93's Avatar
Def sounds like symptoms of a blown coil. Exact same thing happened to my teg a few months back. New cap, new rotor, went to start and no go. Coils tend to do this in our cars, more so if they been in there for a while. Hope u get it running
Old 08-18-2011, 01:02 PM
A very common reason for blowing the coil is cranking the engine with one or more spark plug wires unplugged.
Old 08-18-2011, 01:40 PM
Originally Posted by RonJ@HT
What car?
my heart dropped... when i read this. lol the TIMING BELT is still there in tacked with tension.
how do i do this with the coil? need a tool or can borrow a friend? ha~! if it so happens to be the coil, do i go OEM or autozone? AND what if it is not the coil...?
well, it started... and died while in idle. i am not sure if that makes a difference though.
Old 08-18-2011, 04:16 PM
motegicivic's Avatar
I think you need a multi meter to test the coil, you can get it at a auto store or walmart.
You can get a coil from the parts store for about 70 bucks.
Old 08-18-2011, 05:00 PM
yeah... i just bought (1). today was a cardio day anyway. i put down 3 miles a couple minutes ago. people in the store were like, wtf... LoL. i hope it starts up after i install this.
Old 08-18-2011, 05:08 PM
Let us know.
Old 08-27-2011, 06:12 PM
Kenshiro93's Avatar
And crickets..you try to help someone out and they never follow up..not that I care just saying
Old 08-27-2011, 06:44 PM
EJ8mike's Avatar
He edited his first post.....
spoonhbk11
11
06-09-2019 07:03 PM
infinate bound
03-19-2004 02:25 PM
BadBeck
12-11-2003 05:59 PM
SleeperCivicEX99
09-09-2002 08:48 PM
phildeez
03-15-2002 07:22 PM
Quick Reply: change cap/rotor vehicle will not start
