d16y8
Old May 31, 2006 | 07:36 AM
ekVtecPower's Avatar
Default d16y8
are those motors running obd1?
Old May 31, 2006 | 07:40 AM
GiMpInThaCiv's Avatar
Dont believe so there from 96-00 i believe running obd2a/ obd2b i own a 97 dx and its obd2a So no they arnt. 96-98 is obd2a and 99 - 00 is obd2b
Marauder's Avatar
Default Re: d16y8 (ekVtecPower)
nope...OBD2, its actually, 96-98 motors are OBD2a and 99-00 are OBD2b
D16Z6 are the OBD1 versions.
Old May 31, 2006 | 07:42 AM
which is better?
Old May 31, 2006 | 07:43 AM
All depends on what you are planing on doing with the motor, there both around the same. just obd stuff.
Old May 31, 2006 | 07:44 AM
because im about to swap an LS motor with a b16a transmission .. so which harness will be best? thanks
Old May 31, 2006 | 05:51 PM
soo anyone know?
Old May 31, 2006 | 05:52 PM
JDM-EJ1's Avatar
Default Re: d16y8 (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">nope...OBD2, its actually, 96-98 motors are OBD2a and 99-00 are OBD2b
D16Z6 are the OBD1 versions.</TD></TR></TABLE>
Old May 31, 2006 | 06:01 PM
Default Re: d16y8 (JDM-EJ1)
Old May 31, 2006 | 06:49 PM
help? any LS/VTEC masters here lol
Old May 31, 2006 | 08:55 PM
Default Re: d16y8 (aallbbeerrtttttt)
ok.. i have a 98 civic ex right now and im about to get the LS longblock.. then im buyin a b16a head because it flows better than the b18c head... then im getting the b16a transmission because its shorter gears.. now i was just wonderin what engine harness would be best to run with this modification.. ? thank u.
Old May 31, 2006 | 09:10 PM
Old May 31, 2006 | 09:15 PM
VSM_EK's Avatar
From: In The Oregon Dunes, scaring little kids..., USA
try the hybrid forum
Old May 31, 2006 | 09:58 PM
thehatchninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekVtecPower &raquo;</TD></TR><TR><TD CLASS="quote">ok.. i have a 98 civic ex right now and im about to get the LS longblock.. then im buyin a b16a head because it flows better than the b18c head... then im getting the b16a transmission because its shorter gears.. now i was just wonderin what engine harness would be best to run with this modification.. ? thank u.</TD></TR></TABLE>
b18c head FTW.
Old May 31, 2006 | 10:12 PM
sol2hatch's Avatar
Default Re: d16y8 (thehatchninja)
your harness is fine, you just have to add some wires. there is a thread about it in the FAQ.
BTW: I see your in OKC, good to see someone else in this redneck city, you interested in autocrossing???
Soviet67
Apr 11, 2010 05:58 AM
topshotta
Mar 20, 2010 06:35 PM
EGh22aEG
Sep 5, 2008 11:05 AM
str8drift
Oct 31, 2007 03:34 PM
ekay. jay
Feb 27, 2006 03:45 PM
