obd-1 swap into obd-2 EK
Im swaping an obd-1 lsvtec into my obd-2 EK and need to know what harness to use. The stock dx harness does not plus into the motor at all. So what harness am i supose to use??
* B A N N E D *
Re: obd-1 swap into obd-2 EK (ekay. Jay)
if its a 96-98 use the ex harness from a 96-98, if its a 99-00 use a ex/si harness from a 99-00
Re: obd-1 swap into obd-2 EK (rx7tocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rx7tocivic »</TD></TR><TR><TD CLASS="quote">if its a 96-98 use the ex harness from a 96-98, if its a 99-00 use a ex/si harness from a 99-00</TD></TR></TABLE>
So a 96-98 ex harness wil plug into my obd-1 motor??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay. Jay »</TD></TR><TR><TD CLASS="quote">
So a 96-98 ex harness wil plug into my obd-1 motor??</TD></TR></TABLE>
Yes, the 96-98 EX harness will plug right into the obd-1 motor. The only big thing is, the ECU from your OBD1 motor is not going to fit, you'll have to get a OBD2A ecu or chipped p28 with jumpers.
Re: obd-1 swap into obd-2 EK (99CivicSiBrian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CivicSiBrian »</TD></TR><TR><TD CLASS="quote">Won't it use a different distributor, or atleast some modification to the wiring at the distributor?
B</TD></TR></TABLE>
You'd have to convert the distributer to 96-00 unless you know how to rewire the distributer from OBD1 to OBD2. I once rewire the distributor on an LS from OBD1 to OBD2 and it works fine. Look at the wire colors and look at the connectors, make sure the wire colors matches. Good Luck.
B</TD></TR></TABLE>
jimmhatch
08-22-2004 04:49 PM
