back seat remove?
2 clips, one on each side of the car at the bottom of the rear seats. take those out, and then push the two rear seats apart and comes right out...once those are out..there's a 10mm bolt holding the bottom parts down..take that out and it will all come out.
You have to take the seat backs out first, then the seat bottom. Look for the white clips holding the backs in at the bottom of the seat backs. That doesn't make any sense, does it?
Also, you have to remove the rear carpet from the seats first.
[Modified by Ddub, 3:34 PM 4/14/2002]
what?!!! you ***... just take the seats and carpet out at the same time..
D owNz j00!
Jason-
who just stripped the R of the full interior, carpet, panels, and a/c this weekend
i see the 10mm screw but not sure about the clips. the only thing i see close to being a clip are brown and it clips onto a rod that comes out of the seats and into the side of the car. is that it??
Two things...
1st) how would you be able to see the 10mm screw if you haven't taken the back part of the rear seats out yet? I just removed mine, 10 min ago, and I couldn't see it...
2nd) If you lower the back part of the rear seats and look to the outside of each seat... They have metal rods which connect to the side of the car, on each metal rod is a plastic clip to hold it in place which is what you gotta pop out.
the 10mm screw i'm talking about was under the carpet on the back. i had remove the carpet when i was looking for screws that holds the seats. the two clips are the same one i saw too, so now i know how to do it.
mxl36o
Mar 14, 2007 06:50 AM
