Headgasket question??
Old May 30, 2006 | 06:52 PM
slowteg550's Avatar
Default Headgasket question??
The setup is:
b18a block, darton sleeved @ 85 mm (actually mic out at 84.6 ish)
b18c1 head
I bought a GE 85 mm headgasket, and when I put it on my block to check fitment, it was very very close to the edge of the cylinders, if not even hanging over in a couple of spots. I called GE and told them the deal, and when I mic'd the headgasket it was like 84.6-.7 ish.
My question is, how far from the edge of the cylinder do you need the headgasket to lay? I know they crush some when you torque the head.
I am planning on getting a true 85 mm gasket, so that it would be .3 or so mm bigger than the bore, is this too much? Anyone info is greatly appreciated...
Old May 30, 2006 | 11:14 PM
BuddhaSiR's Avatar
Default Re: Headgasket question?? (slowteg550)
overhanging would not be a good thing.
Old May 31, 2006 | 04:10 AM
slowteg550's Avatar
Default Re: Headgasket question?? (BuddhaSiR)
Yeah, I know...it will cause detonation. I just need to know if it's ok if the hg is .3-.4 mm from the edge of the cylinders....
Old Jun 1, 2006 | 05:17 PM
slowteg550's Avatar
Old Jun 1, 2006 | 07:30 PM
slowteg550's Avatar
need some help
Old Jun 1, 2006 | 11:53 PM
slowteg550's Avatar
Old Jun 3, 2006 | 04:47 AM
slowteg550's Avatar
Old Jun 3, 2006 | 06:42 AM
non-VTEC's Avatar
can you not get a replacment gasket form GE?
Old Jun 3, 2006 | 08:59 PM
slowteg550's Avatar
Default Re: Headgasket question?? (non-VTEC)
yes, but I need to know if an actual 85 mm gasket will be too big for a bore that mic's out at like 84.6 mm... my question is, exactly how much bigger can your gasket be than your bore b/c right not its dead on, and on the verge of overlapping (maybe overlapping slightly in a few spots), and I know it will crush out some...
my96civiccoupe
Aug 5, 2011 04:36 PM
jeffry6996
May 2, 2008 02:45 PM
slowteg550
May 21, 2006 07:33 PM
Mr Hammond
May 9, 2003 07:16 PM
