5 wire o2 wiring to 4 wire o2
Old May 30, 2006 | 06:51 PM
ham's Avatar
ham
Default 5 wire o2 wiring to 4 wire o2
Im sure this was covered somewhere but the search deficiencies wont allow me to narrow my search.
anyways, i need to know how to convert my stock 5 wire wideband o2 (94 vx) to run a 4 wire o2 because i will be swapping the ECU.
thanks.
Old May 31, 2006 | 03:20 AM
ham's Avatar
ham
Default Re: 5 wire o2 wiring to 4 wire o2 (ham)
bump
Old May 31, 2006 | 12:32 PM
ham's Avatar
ham
bump please
Old May 31, 2006 | 12:44 PM
Relic1's Avatar
if you're changing your engine harness with a swap... 6th post in the sticky. https://honda-tech.com/zerothread/642479
poison
VX O2 sensor fix:
If you have a VX model Civic, and you do NOT use the VX engine harness, in order for your O2 sensor to properly work, you need to move the ORG/BLU wire from the 4th connector at the shock tower harness, and move it matching with the WHT wire on the 4 wire embedded engine harness.
if you're keeping the D15Z1 and simply running it with a P28 then there are a few wiring changes that need to be done.
Post up your plans and I'll let you know what you have to do.
Old May 31, 2006 | 01:49 PM
ham's Avatar
ham
Default Re: (Relic1)
i just plan on swapping some motor soon. so i will need a p28 and the proper wiring.
vxcivic
Feb 16, 2006 11:35 AM
Built B16A
Oct 18, 2004 03:10 AM
1990hondaHF
Aug 24, 2003 01:46 AM
civic_dreams95
Mar 11, 2003 11:08 PM
