5 to 4 wire O2 wiring help.
I have a p28 in an VX and d15b vtec engine. The p28 uses a 4 wire O2 and the VX harness uses 5 wires. What color wire goes to what? Thanks.
Re: 5 to 4 wire O2 wiring help. (1990hondaHF)
yel/blk-A25 - 12 volt switch
org/blk-A6 - O2 heater ground
grn/wht - sensor ground
wht/red - O2 signal wire
run it directly to the ecu for faster convenience. hope that helps. if not. IM
Re: 5 to 4 wire O2 wiring help. (ARCSEC28)
There is an extra step for the VX, there is a wire that is in a different pin that you have to move. Here is some pics and directions on the repinning.
http://www.hondaswap.com/forum...14242
Combustion Contraption
05-30-2011 10:50 AM
Built B16A
10-18-2004 03:10 AM
Houston Hatchback
04-23-2003 05:17 PM
