GSR getting so smoke
Old May 30, 2006 | 01:17 PM
DelSolMarine's Avatar
Default GSR getting so smoke
i was getting on my car and my friend said it was smokin pretty bad when i was getting on it... and idea what that could be? i got the motor from hmotorsonline about 3 months ago its a B18C in a del sol
Old May 30, 2006 | 01:58 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: GSR getting so smoke (DelSolMarine)
Piston rings, valve seals, PCV valve... do a compression/leakdown test to find out.
Old May 30, 2006 | 07:35 PM
Default Re: GSR getting so smoke (LSVT3K 91 C1V1C)
ok for a compression test just go to any mechanic shop and they should be able to do it?
Old May 30, 2006 | 08:58 PM
is that basically oil burning though?
Old May 30, 2006 | 10:00 PM
ChillOutWayne's Avatar
How often do you beat on it? It could just be the typical puff of carbon/fuel that most cars get after whomping on it after a while. Get yurself a compression test and check out c-speedracing.com for directions. It will take 30 mins total and its free to do. Leakdown test would be good also, hows the oil level?
DAn
Old May 30, 2006 | 10:43 PM
BuddhaSiR's Avatar
Default Re: GSR getting so smoke (ChillOutWayne)
What color is the smoke? White, blueish, or Black?? overheating? check your oil level. your most likely burning oil.
Old May 30, 2006 | 10:57 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: GSR getting so smoke (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">What color is the smoke? White, blueish, or Black?? overheating? check your oil level. your most likely burning oil. </TD></TR></TABLE>
Old May 31, 2006 | 06:30 PM
Default Re: GSR getting so smoke (JDM_Ej)
not sure what color the smoke is what just told it was smoking.. and yes i am burning some oil... i need to do a compression test and leakdown test right?
94allmotor
15
Sep 25, 2007 05:31 PM
Fat Chick Magnet
Nov 24, 2006 02:50 PM
tommy.
11
Mar 26, 2006 10:49 AM
CRX SiR T
Nov 24, 2003 12:49 PM
someday
Nov 4, 2003 07:12 PM
