Comp. Test results....??
Old Nov 24, 2003 | 12:31 PM
CRX SiR T's Avatar
Default Comp. Test results....??
Well, i warmed the motor up and got these numbers...
1- 160
2- 150
3- 150
4- 160
I decided to go ahead and drop a small cap-full of oil into the cylinders to see how that would affect the numbers. This is what i got..
1- 210
2- 220
3- 210
4- 240
I know the car should smoke for a little while to burn off the oil, but it is just smoking profusely and wont stop. I did the test to see if i had blown my headgasket, but now i'm worried about the rings What do you think?
BTW, the motor is a 9.5:1 compression b16
Old Nov 24, 2003 | 12:45 PM
boosted_dc2's Avatar
Default Re: Comp. Test results....?? (CRX SiR T)
seems kinda low but they are all relatively the same......did it smoke before you dumped the oil down????
Old Nov 24, 2003 | 12:48 PM
CRX SiR T's Avatar
Default Re: Comp. Test results....?? (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">seems kinda low but they are all relatively the same......did it smoke before you dumped the oil down????</TD></TR></TABLE>
only a little, and very rarely....usually happened when i was deaccellerating
Old Nov 24, 2003 | 12:49 PM
yellowhonda88's Avatar
Thats what i was wondering, if he did the test because it was smoking, and you added a little oil and it got higher numbers, that generally points to worn rings. However, my bone stock 10.2:1 B16 only makes 180-185 all across, so a 9.5:1 at 160 psi sounds about right....
Brett
jcskyhigh
Jul 25, 2007 01:24 PM
Fat Chick Magnet
Nov 24, 2006 02:50 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
nekoabandoned
Jul 24, 2006 03:39 PM
aut0tek
Apr 10, 2004 08:30 PM
